I want to get a wav format voice through my microphone.
(For use with IBM STT)
For the "node-red-contrib-mic" package, voice input is not working.
For the microphone node in the "node-red-contrib-browser-utils" package, voice input works. However, it is difficult to use it on IoT devices because the input is performed by clicking the button directly.
Is there only a way to click on a node in the browser screen to perform input from node-red?
For example, I want to use something like a GPIO button as a trigger of this flow.
Step 1 would be to search on flows.nodered.org for any other nodes that might do what you are looking for. For example theres a node for USB microphones.
Certainly, lots of ways. Here are a few off the top of my head:
- Use an Amazon Alexa or Google Home interface
- Raspberry Pi running Node-RED, wire up a button to a GPIO
- Use Dashboard for a web interface
- Use a hacked Amazon button
- Create an ESP8266 or ESP32 based button interface over WiFi :
- Create a Telegram bot for a command or conversational interface
- Use the IFTTT "Do" app
- Wire up a soil sensor so that you trigger the flow when you water a plant
- Use a light sensor for hands-free activation
Why not use several? There are examples around for all of these.
