How it does.
The node red docs describing how to handle messages will show you how to get the path to that item from the payload.
https://nodered.org/docs/user-guide/messages
Thanks for express answer Colin. Now the problem is almost solved.
I use change node .
Set msg.payload.value
to msg.payload
Value came instead "[Circular ~]"
[{"id":"d4170f7d.697fd","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"6791bfb0.f0061","type":"snmp walker","z":"d4170f7d.697fd","host":"10.67.20.28","community":"public","version":"1","oids":"1.3.6.1.4.1.534.1.4.4.1.3","timeout":5,"name":"CMUPS CUR. OUT","x":359.5,"y":176,"wires":[["40588324.d68c3c"]]},{"id":"34e11622.78691a","type":"inject","z":"d4170f7d.697fd","name":"","topic":"","payload":"","payloadType":"date","repeat":"5","crontab":"","once":false,"onceDelay":0.1,"x":100,"y":177,"wires":[["6791bfb0.f0061"]]},{"id":"94ebf0be.198b3","type":"debug","z":"d4170f7d.697fd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1090,"y":179,"wires":[]},{"id":"40588324.d68c3c","type":"json","z":"d4170f7d.697fd","name":"","property":"payload","action":"obj","pretty":false,"x":581.5,"y":177,"wires":[["9034130b.73bdd"]]},{"id":"9034130b.73bdd","type":"function","z":"d4170f7d.697fd","name":"","func":"msg.payload = msg.payload [0]\nreturn msg;","outputs":1,"noerr":0,"x":773.5,"y":176,"wires":[["43d84565.cbe5cc"]]},{"id":"43d84565.cbe5cc","type":"change","z":"d4170f7d.697fd","name":"","rules":[{"t":"set","p":"payload.value","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":908.5,"y":286,"wires":[["94ebf0be.198b3"]]}]
I was solve this problem wrote that msg.payload = msg.payload [0].value at theFunction node.
Thnks for all.
Best regards
