I feel I understand the basics, with using a value from a message, but at a loss on how you choose one message from a stream after a split node.
I am using a SNMP-table node and using a split, which works well, but the payload "stream" is 16 msgs all with a payload. Using the attachment how would ask for payload[3] for only msg 9 (as highlighted)?
At the moment I am just trying to output this to debug (not sure if that possible)
You pick out something recognisable and compare that using a switch node. In your case here, topic would be == to the string 9
As for then getting the item 3 of payload, use a change node to Set the value of msg.payload to the value of msg.payload[3] (or just use msg.payload[3] in your next node if it permits that)
tip to help you getting correct path to an item
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
