How to set API KEY and Service Endpoint through environment variables for IBM Watson "Language Translator" node?
I would like to keep my IBM Watson credentials outside the node-red flow by setting them in environment variables.
The problem is that the watson translator node is not substituting ${XXX} by the contents of the environment variable XXX.
can you double check there are no whitespace or space characters before the $ and after the } and that the environment variable actually exists
Thanks a lot: that was indeed the first issue: It didn't exist.
The second issue I encountered when defining it: was that I had defined it as follows in my env file:
WATSON_LANGUAGE_TRANSLATOR_APIKEY="gYHe7_-....k_"
which is also not correct - it should be defined without the double quotes as follows:
WATSON_LANGUAGE_TRANSLATOR_APIKEY=gYHe7_-....k_
So when removing the double quotes in my env file it worked as a charm.
Thanks a lot !
