How to use node-red-node-dropbox without a browser?
How can I use 'node-red-node-dropbox' without a browser on localhost?
I use a NodeRed instance in which I do not have access to the browser to perform steps to obtain the 'Access Code' and the 'Refresh Token'.
I read several topics about 'node-red-node-dropbox', but the examples are using the browser to obtain the 'Access Code' and the 'Refresh Token'. But how do I get the 'Access Code' and 'Refresh Token' without access to the browser?
Hi @georgevbsantiago, welcome to the forum.
Is there any reason to believe that you must obtain a token on the same machine as runs Node-red?
Since you must be able access your Node-red instance with a browser from somewhere, does that not let you set up the token?
Have you tried obtaining one using a completely seperate PC and browser and copying the values manually into Node-red?
Hello, Thanks for the posts
I read some posts about node-red-node-dropbox (mentioned below) and understood that access via oauth2 token would have to be done on the same machine that generates it.
Ex: If NodeRed (node-red-node-dropbox) is on VPS 'A', the oauth2 token would have to be generated in the browser of VPS 'A' instance to work.
I understood that if the user manipulated NodeRed (node-red-node-dropbox) on VPS 'A', but tried to create the token on their personal computer (notebook, PC...), it would not work.
If it is possible to manipulate NodeRed (node-red-node-dropbox) on VPS 'A', and create the token on my notebook to later insert it into node-red-node-dropbox) on VPS 'A', then that's great!
Question: Is there no way to avoid manually creating the oauth2 token by opening Dropbox through the browser?
I upload it to Dropbox via script, using the access token (old way), using the SDK-Dropbox JavaScript and just providing 'token' and 'account_id', without prior access via the browser.
Thank you for your attention
OK, I read the post you linked to but didn't understand it all (and not just the Portuguese!).
Maybe someone else more knowledgable can assist you.
I managed to generate the refresh token through my browser (laptop) and inserted it into node-red-node-dropbox. Thanks.
