How to use themes with Monaco editor
With the Monaco editor available as part of Node-RED 2.0.0-beta.2 is there a set of instructions for activating a theme and installing new themes?
Hi @zenofmud
Only what is provided in the settings file:
(btw please keep questions about the beta to the beta thread)
For info, there's a very nice interactive demo of Monaco themes here - https://editor.bitwiser.in/
the problem is that that says the themes are in:
packages/node_modules/@node-red/editor-client/src/vendor/monaco/dist/theme
and I can't find that in MacOS
You can see the list here: node-red/packages/node_modules/@node-red/editor-client/src/vendor/monaco/dist/theme at dev · node-red/node-red · GitHub
I'm using one from the list and it is not showing up. I
  • change settings.js,
  • save,
  • stop NR,
  • clear browser cache
  • start NR
but editor looks the same. here is my settings.js from the editorTheme to the end of the file. What have I messed up?
    // Customising the editor
    editorTheme: {
        projects: {
            // To enable the Projects feature, set this value to true
            enabled: true,
            workflow: {
                // Set the default projects workflow mode.
                //  - manual - you must manually commit changes
                //  - auto - changes are automatically committed
                // This can be overridden per-user from the 'Git config'
                // section of 'User Settings' within the editor
                mode: "manual"
    	codeEditor: {
            /** Select the text editor component used by the editor.
             * Defaults to "ace", but can be set to "ace" or "monaco"
            lib: 'monaco', // 'ace',
            options: {
                /** The follow options only apply if the editor is set to "monaco"
                 * theme - must match the file name of a theme in
                 * packages/node_modules/@node-red/editor-client/src/vendor/monaco/dist/theme
                 * e.g. "tomorrow-night", "upstream-sunburst", "github", "my-theme"
                theme: 'upstream-sunburst', // 'vs',
                //theme: 'hc-black', // 'vs',
                /** other overrides can be set e.g. fontSize, fontFamily, fontLigatures etc.
                 * for the full list, see https://microsoft.github.io/monaco-editor/api/interfaces/monaco.editor.istandaloneeditorconstructionoptions.html
                fontSize: 14,
                //fontFamily: "Cascadia Code, Fira Code, Consolas, 'Courier New', monospace",
                fontFamily: "Consolas, 'Courier New', monospace",
                fontLigatures: false,
                colorDecorators: true,
                dragAndDrop: true,
                linkedEditing: true,
                minimap: {
                    enabled: false,
                mouseWheelZoom: true,
                showFoldingControls: 'always',
                useTabStops: true,
Oh - thats odd.
It works for me...
Result...
Silly questions (but they have to be asked) are you editing the correct settings.js? Did you restart node-red? Did you refresh browser?
<...head smack...><...head smack...><...head smack...>
Argh! I deffinately haven had enouth coffee today. I kept looking at the editor thinking it was going to change the entire editor, not what you see in the function node.
(...head held down very very low...)
ahhh good ol Mondays
Before I found this thread I was using the browser plugin 'Stylus' as I do for many things which end up not having a user editable way to change things and was able to pretty quickly come up with some slight edits by changing some css properties in a few places such as:
.monaco-editor .margin {
    background-color: #303235;
.monaco-editor, .monaco-editor-background, .monaco-editor .inputarea.ime-input {
then for text there were various items like:
.mtk1 {
    color: #d2caca;
.mtk20 {
    color: #CFC260;
.mtk6 {
    color: #7E9F58;
