How to use tnsnames.ora in oracle node
I found finally the only oracle node that seems to work on windows 7: node-red-contrib-oracledb-mod
But now I fail to connect to the data base because the tnsnames.ora is not found (I think so). I get following error:
"Oracle-server error connection to myDBserver:1554/P54: ORA-12514: TNS:listener does not currently know of service requested in connect descriptor"
PATH-variables for TNS_HOME and TNS_ADMIN are set properly and tnsnames.ora is in the admin directory.
Has anyone any idea of how to solve this? Getting Oracle work is a really hard task.
Thanks in advance.
Meanwhile I made some tests.
With node.js I can use the full Oracle connection string i.e.
(DESCRIPTION =(ADDRESS = (PROTOCOL = TCP)(HOST = myDBserver)(PORT = 1554))(CONNECT_DATA =(SID = P54)))
via the dbconfig.js but in node-red I have to specifiy server, port and database, i.e. I cannot hand over the full configuration.
