You can simply watch the directory and use a switch node after the watch to filter the .xml and .txt files
Demo flow (use CTRL+I to import it)
[{"id":"6fdfaaf255b50a10","type":"watch","z":"3642c7ee286f9c17","name":"","files":"c:/temp/","recursive":true,"x":1290,"y":260,"wires":[["6072ba90a762695a"]]},{"id":"6072ba90a762695a","type":"switch","z":"3642c7ee286f9c17","name":"","property":"filename","propertyType":"msg","rules":[{"t":"regex","v":"\\.txt$","vt":"str","case":false},{"t":"regex","v":"\\.xml$","vt":"str","case":false}],"checkall":"true","repair":false,"outputs":2,"x":1590,"y":260,"wires":[["e337f5a1709a6001"],["aae583f0053d1803"]]},{"id":"442f6f3a11522f39","type":"inject","z":"3642c7ee286f9c17","name":"filename: test1.txt","props":[{"p":"payload"},{"p":"filename","v":"test1.txt","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1320,"y":20,"wires":[["fb07d3fdd7b9f2ce"]]},{"id":"e9e772d7436bb193","type":"inject","z":"3642c7ee286f9c17","name":"filename: test1.txt.zip","props":[{"p":"payload"},{"p":"filename","v":"test1.txt.zip","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1340,"y":100,"wires":[["fb07d3fdd7b9f2ce"]]},{"id":"4972b130870b365f","type":"inject","z":"3642c7ee286f9c17","name":"filename: test1.pdf","props":[{"p":"payload"},{"p":"filename","v":"test1.pdf","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1330,"y":140,"wires":[["fb07d3fdd7b9f2ce"]]},{"id":"113a52d49a3a6226","type":"inject","z":"3642c7ee286f9c17","name":"filename: test1.xml","props":[{"p":"payload"},{"p":"filename","v":"test1.xml","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1330,"y":180,"wires":[["fb07d3fdd7b9f2ce"]]},{"id":"e337f5a1709a6001","type":"debug","z":"3642c7ee286f9c17","name":"txt files -> ","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"filename","statusType":"msg","x":1740,"y":220,"wires":[]},{"id":"aae583f0053d1803","type":"debug","z":"3642c7ee286f9c17","name":"xml files -> ","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"filename","statusType":"msg","x":1750,"y":300,"wires":[]},{"id":"33beb950e5066b5c","type":"inject","z":"3642c7ee286f9c17","name":"filename: test2.txt","props":[{"p":"payload"},{"p":"filename","v":"test2.txt","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1320,"y":60,"wires":[["fb07d3fdd7b9f2ce"]]},{"id":"13fb944742cce589","type":"inject","z":"3642c7ee286f9c17","name":"filename: test2.xml","props":[{"p":"payload"},{"p":"filename","v":"test2.xml","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1330,"y":220,"wires":[["fb07d3fdd7b9f2ce"]]},{"id":"fb07d3fdd7b9f2ce","type":"junction","z":"3642c7ee286f9c17","x":1500,"y":80,"wires":[["6072ba90a762695a"]]}]
