How use flow variable?
I get the id of a Tunein station that I memorize
    if(data[i]["data-nextguideitem"] != null
        && data[i]["data-testid"] === "guideItem-0")
        msg.payload = data[i]["data-nextguideitem"];
        if(flow.get("franceInter") !== msg.payload)
            flow.set("franceInter", msg.payload);
and I want to inject into a node Sonos :
$env(flow.get("franceInter"))
but I get :
```group.play.tunein: radio id (payload) >>$env(flow.get("franceInter")) wrong syntax. Regular expr. - see documentation :: Details: none```
Thank for your help
I don't think that is correct syntax.
$env gets the environment variable.
So you are doing to get things.
I also don't get what that you are wanting to do with the code you posted.
I didn't import the bigger code you posted because I don't think I have that second node and so won't be able to test it anyway.
I would like to call my variable from this node
Sorry. I have no knowledge of that node or how it works.
Just the code you posted doesn't look right.
Only "string" or "number" ?
package "node-red-contrib-sonos-plus" - "Universal" node
You will have to retrieve the context before the sonos node and pass it in as a payload. You cannot retrieve it as your screenshot because its expecting a string or a number.
Have you read the link see documentation?
Yes but I don't see the solution ...
If you are saving the radio station id to flow.context in the format described in see documentation -
REGEX check. the TuneIn radio station id such as 's97033'. Don't add additional blanks or whitespace.
then add a change node before the sonos node to retrieve that data, and feed it into sonos as a payload
flow
I don't use this node, so can't help you further, but hopefully another user may be able to.
Ok thank. I tried without success
What is the value of that ?
The value is : s24875
I found out how to do it
I load the variable from a function before injecting it into the node, leaving the payload field empty
Thanks to everyone who took the time
