How would you style this dashboard (2)?
The attached flows make up a working dashboard displaying weather info (worldwide) from the Norwegian Met. Office, chosen because it requires no API key.
There is a flow to retrieve the data and cache it to avoid breaking their conditions of use & a flow for each of the dashboard layouts Grid, Fixed, Notebook & Tabs.
The only CSS styling used is to draw borders around widgets and groups which makes it easier to observe how each dashboard layout is assembled.
If you download these, please pay attention to the requirements listed in the comment nodes on the first flow.
How would you improve the presentation of this data?
  • The many ways of picking a location are just a way to include different widgets. Which is most pleasing to the eye?
  • Are there better config choices for individual widgets?
  • What theme settings do you prefer? Are the default column/row heights the best?
  • Do the core widgets share an overall style? Can you use CSS to beautify the dashboard & give it a coherent look?
  • Maybe pick a single dashboard layout to enhance.
  • Consider setups for different display sizes.
No 1. yr.no connection
[{"id":"4acfb18b34dffa18","type":"tab","label":"Weather - YR.NO ","disabled":false,"info":"","env":[]},{"id":"a7dde7584846a5ea","type":"group","z":"4acfb18b34dffa18","name":"Fetch & cache forecasts from yr.no","style":{"label":true},"nodes":["7d01f69176328855","b2ed74cc5a434824","a4cdcbf15bdd3234","c4943cd89b5306df","193bd9bfa4a24efb","d4785b74e14d73a9","107fefb010e5d1fa","71d96107a171e3fe"],"env":[{"name":"EMAILADDRESS","value":"foo@bar.com","type":"str"}],"x":14,"y":399,"w":872,"h":122},{"id":"dc3fb155bf7df03e","type":"group","z":"4acfb18b34dffa18","name":"Fetch meteogram from yr.no unless one exists < 1hr old. ======>>> NB Define Environment Variables!","style":{"label":true},"nodes":["9135f5649b320258","65bc6205c41f5cc4","89ad44300b448c7e","07a4062d2c323d9c","d42ac7c1b5719dd1","464b8b89b801411f"],"env":[{"name":"STATICROOT","value":"/home/pi/.node-red/node-red-static/","type":"str"},{"name":"SUBDIRECTORY","value":"yr.no/","type":"str"}],"x":8,"y":119,"w":878,"h":268},{"id":"e22c0085760720e7","type":"group","z":"4acfb18b34dffa18","name":"Setup locations of interest","style":{"label":true},"nodes":["2e3967a1027bc4d3","d8054d40c543f1f7","75121ecf14095b8c"],"x":14,"y":19,"w":872,"h":82},{"id":"9135f5649b320258","type":"group","z":"4acfb18b34dffa18","g":"dc3fb155bf7df03e","name":"Time to download a new copy?","style":{"label":true,"label-position":"ne"},"nodes":["c231b94182c4636d","bd19ecd670f569b6","2ab9447939b5dc72","e934c57663be7fe2","a6431771f1c8806d","852c6ce2310a0e76","7e92783328c7e594","72f301c0e6975103","17e55033247ce0cf"],"x":34,"y":199,"w":702,"h":162},{"id":"7d01f69176328855","type":"http request","z":"4acfb18b34dffa18","g":"a7dde7584846a5ea","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"other","keyValue":"User-Agent","valueType":"msg","valueValue":"whoami"},{"keyType":"other","keyValue":"If-Modified-Since","valueType":"msg","valueValue":"modified"}],"x":630,"y":460,"wires":[["c4943cd89b5306df"]]},{"id":"b2ed74cc5a434824","type":"link in","z":"4acfb18b34dffa18","g":"a7dde7584846a5ea","name":"Get Forecast","links":[],"x":55,"y":480,"wires":[["d4785b74e14d73a9"]]},{"id":"a4cdcbf15bdd3234","type":"link out","z":"4acfb18b34dffa18","g":"a7dde7584846a5ea","name":"ReturnGot","mode":"return","links":[],"x":845,"y":480,"wires":[]},{"id":"c4943cd89b5306df","type":"function","z":"4acfb18b34dffa18","g":"a7dde7584846a5ea","name":"Cache","func":"var forecastdata = flow.get('forecastdata') || {}\nconst now = new Date()\nforecastdata[msg.location.code] =  {\n    //\"location\": msg.location,\n    \"cached\": now,\n    \"expires\": msg.headers.expires,\n    \"modified\": msg.headers[\"last-modified\"],\n    \"meta\": msg.payload.properties.meta,\n    \"timeseries\": msg.payload.properties.timeseries\n}\nflow.set('forecastdata', forecastdata)\nmsg.payload= forecastdata[msg.location.code]\nmsg.payload.fromcache = false\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":770,"y":460,"wires":[["a4cdcbf15bdd3234"]]},{"id":"193bd9bfa4a24efb","type":"function","z":"4acfb18b34dffa18","g":"a7dde7584846a5ea","name":"Cached?","func":"var forecastdata = flow.get('forecastdata') || {}\n//node.warn (msg.location.name + \" (\" + msg.location.code + \")\")\nconst cache = forecastdata[msg.location.code]\nmsg.modified = \"\"\nif (cache) {\n    msg.modified = cache.modified\n    const cachexpires = new Date(cache.expires).getTime()\n    const now = new Date().getTime()\n    if (now > cachexpires) \n    {\n        //node.warn (\"cache expired, will request again\")\n    }\n    else { // \"don't repeat requests until the time indicated in the Expires response header\"\n        //node.warn (\"Returning cached forecast\") // return cached data\n        msg.payload = cache\n        msg.payload.fromcache = true\n        return [null, msg]\n    }\n}\nelse {\n    //node.warn (\"Not cached, new request\")\n}\nmsg.url = \"https://api.met.no/weatherapi/locationforecast/2.0/compact?lat=\" + msg.location.lat + \"&lon=\" + msg.location.lon\nreturn [msg, null]\n","outputs":2,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":480,"wires":[["107fefb010e5d1fa"],["a4cdcbf15bdd3234"]]},{"id":"d4785b74e14d73a9","type":"change","z":"4acfb18b34dffa18","g":"a7dde7584846a5ea","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"location","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":170,"y":480,"wires":[["193bd9bfa4a24efb"]]},{"id":"c231b94182c4636d","type":"fs-ops-stats","z":"4acfb18b34dffa18","g":"9135f5649b320258","name":"","path":"/.","pathType":"str","filename":"fullpathname","filenameType":"msg","stats":"stats","sizeType":"msg","x":260,"y":240,"wires":[["bd19ecd670f569b6"]]},{"id":"bd19ecd670f569b6","type":"function","z":"4acfb18b34dffa18","g":"9135f5649b320258","name":"How old is it?","func":"const now= new Date()\nconst age = now.getTime() - Math.round(msg.stats.mtimeMs) \nmsg.payload = age/1000 // age in seconds\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":240,"wires":[["e934c57663be7fe2"]]},{"id":"2ab9447939b5dc72","type":"fs-ops-access","z":"4acfb18b34dffa18","g":"9135f5649b320258","name":"File?","path":"/.","pathType":"str","filename":"fullpathname","filenameType":"msg","read":true,"write":true,"throwerror":false,"x":110,"y":240,"wires":[["c231b94182c4636d"],["a6431771f1c8806d"]]},{"id":"e934c57663be7fe2","type":"switch","z":"4acfb18b34dffa18","g":"9135f5649b320258","name":"> 1hr?","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"3600","vt":"num"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":270,"y":280,"wires":[["852c6ce2310a0e76"],["72f301c0e6975103"]]},{"id":"a6431771f1c8806d","type":"change","z":"4acfb18b34dffa18","g":"9135f5649b320258","name":"No file","rules":[{"t":"set","p":"payload","pt":"msg","to":"10000","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":130,"y":280,"wires":[["e934c57663be7fe2"]]},{"id":"852c6ce2310a0e76","type":"change","z":"4acfb18b34dffa18","g":"9135f5649b320258","name":"Setup curl","rules":[{"t":"set","p":"payload","pt":"msg","to":"\"curl https://www.yr.no/en/content/\" & location.code & \"/meteogram.svg -o \" & fullpathname & \" --create-dirs\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":280,"wires":[["7e92783328c7e594"]]},{"id":"7e92783328c7e594","type":"exec","z":"4acfb18b34dffa18","g":"9135f5649b320258","command":"","addpay":"payload","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"get pic","x":590,"y":260,"wires":[["72f301c0e6975103"],[],[]]},{"id":"464b8b89b801411f","type":"comment","z":"4acfb18b34dffa18","g":"dc3fb155bf7df03e","name":"README About Downloading Meteograms","info":"Meteogram images are downloaded from yr.no by curl and saved in a static data directory.\n\nYou must have httpStatic defined in settings.js so it knows where to put them\n\nDefine env vars STATICROOT & SUBDIRECTORY in the environment for this group\neg STATICROOT =   /home/pi/.node-red/node-red-static/ (same as httpStatic in settings.js)\nand SUBDIRECTORY = yr.no/\n\nso filenames will be downloaded eg /home/pi/.node-red/node-red-static/yr.no/filename.svg\nand served from /yr.no/filename.svg\n\nThe age of the file is used as a rudimentary cache","x":200,"y":160,"wires":[]},{"id":"65bc6205c41f5cc4","type":"fs-ops-access","z":"4acfb18b34dffa18","g":"dc3fb155bf7df03e","name":"Directory?","path":"","pathType":"str","filename":"directory","filenameType":"msg","read":true,"write":true,"throwerror":false,"x":670,"y":160,"wires":[["2ab9447939b5dc72"],["89ad44300b448c7e"]]},{"id":"89ad44300b448c7e","type":"function","z":"4acfb18b34dffa18","g":"dc3fb155bf7df03e","name":"Error","func":"node.warn (\"Directory \" + msg.payload + \" is not readable. Is httpStatic setup?\")","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":200,"wires":[[]]},{"id":"07a4062d2c323d9c","type":"change","z":"4acfb18b34dffa18","g":"dc3fb155bf7df03e","name":"","rules":[{"t":"set","p":"location","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"directory","pt":"msg","to":"STATICROOT","tot":"env"},{"t":"set","p":"subdirectory","pt":"msg","to":"SUBDIRECTORY","tot":"env"},{"t":"set","p":"filename","pt":"msg","to":"location.code & \".svg\" ","tot":"jsonata"},{"t":"set","p":"fullpathname","pt":"msg","to":"directory & subdirectory & filename","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":160,"wires":[["65bc6205c41f5cc4"]]},{"id":"d42ac7c1b5719dd1","type":"link in","z":"4acfb18b34dffa18","g":"dc3fb155bf7df03e","name":"Get Meteogram","links":[],"x":385,"y":160,"wires":[["07a4062d2c323d9c"]]},{"id":"72f301c0e6975103","type":"change","z":"4acfb18b34dffa18","g":"9135f5649b320258","name":"Tweek","rules":[{"t":"set","p":"payload","pt":"msg","to":"subdirectory & filename","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":320,"wires":[["17e55033247ce0cf"]]},{"id":"17e55033247ce0cf","type":"link out","z":"4acfb18b34dffa18","g":"9135f5649b320258","name":"Got Meteogram","mode":"return","links":[],"x":695,"y":320,"wires":[]},{"id":"2e3967a1027bc4d3","type":"link out","z":"4acfb18b34dffa18","g":"e22c0085760720e7","name":"Setup locations","mode":"link","links":["4c4910cb28922165","8fcca52857e4ad81","301624436e7afd02","eede667125cf087c"],"x":780,"y":60,"wires":[],"l":true},{"id":"d8054d40c543f1f7","type":"inject","z":"4acfb18b34dffa18","g":"e22c0085760720e7","name":"Define your locations here!","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"[{\"name\":\"Canberra\",\"icon\":\"grass\",\"code\":\"2-2172517\",\"lat\":-35.3067,\"lon\":149.1912},{\"name\":\"Lima\",\"icon\":\"tree-outline\",\"code\":\"2-3936456\",\"lat\":-12.0242,\"lon\":-77.1103},{\"name\":\"Kampala\",\"icon\":\"palm-tree\",\"code\":\"2-232422\",\"lat\":0.044,\"lon\":32.4414},{\"name\":\"Madrid\",\"icon\":\"tree\",\"code\":\"2-3117735\",\"lat\":40.4951,\"lon\":-3.569},{\"name\":\"Pyongyang\",\"icon\":\"forest-outline\",\"code\":\"2-1871859\",\"lat\":39.2007,\"lon\":125.675},{\"name\":\"Seattle\",\"icon\":\"pine-tree\",\"code\":\"2-5809844\",\"lat\":47.4435,\"lon\":-122.3058}]","payloadType":"json","x":440,"y":60,"wires":[["2e3967a1027bc4d3"]]},{"id":"75121ecf14095b8c","type":"comment","z":"4acfb18b34dffa18","g":"e22c0085760720e7","name":"README About Locations","info":"You can define a group of locations as an array of objects.\nSorry, I couldn't find an easy way to avoid having both location code and latitude/longitude.:\n[\n    {\n     \"name\": \"Canberra\",  // Used everywhere\n     \"icon\": \"grass\",     // Icon for button group\n     \"code\": \"2-2172517\", // The yr.no location code used to retrieve the meteogram - use search option on yr.no\n     \"lat\": -35.3067,     // Latitude & longitude used to retrieve the forecast\n     \"lon\": 149.1912      // yr.no terms state max 4dp\n    },\n]","x":150,"y":60,"wires":[]},{"id":"107fefb010e5d1fa","type":"change","z":"4acfb18b34dffa18","g":"a7dde7584846a5ea","name":"email","rules":[{"t":"set","p":"whoami","pt":"msg","to":"\"Node-RED foo@bar.com\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":460,"wires":[["7d01f69176328855"]]},{"id":"71d96107a171e3fe","type":"comment","z":"4acfb18b34dffa18","g":"a7dde7584846a5ea","name":"README About Email Address","info":"The yr.no terms of service say you may be banned unless you identify yourself in http headers.\nThey require a site name and contact email (I use \"Node-RED myname@gmail.com\")\n\nTo comply, please put your details in the \"email\" node","x":170,"y":440,"wires":[]}]
No 2 Grid layout
[{"id":"7cbab40455148818","type":"tab","label":"Grid layout","disabled":false,"info":"","env":[]},{"id":"7d4dc1d92148e514","type":"group","z":"7cbab40455148818","name":"Current Weather","style":{"label":true},"nodes":["51f434a5cae8205f","c1534aab37af0fe7","e72095c3c957fa28","5924dba7ae857d85","7fe54a223140edd1","76f76fb5bbf14592","cd3ae270cc151264","89c27384c32f3f40","d95533dff0506135","0f78871f5accc1be"],"x":474,"y":239,"w":392,"h":242},{"id":"4a3b7fdba3b765f5","type":"group","z":"7cbab40455148818","name":"Statistics","style":{"label":true},"nodes":["de933fb7d9913984","49639fb6d42fd0c4","422bb58242222c78","cf094d9bcd67e11d","5fe578a8840fdf04","0f338e9e6035dc28","b50876501a9e8e02"],"x":14,"y":379,"w":452,"h":162},{"id":"c8ded7141c7ee18e","type":"group","z":"7cbab40455148818","name":"Meteogram","style":{"label":true},"nodes":["931667020aadabb8","b1220308c3ee3924","b786cdc988aa4d18","936c716a94a76d08"],"x":14,"y":239,"w":452,"h":122},{"id":"e63e8134815e9780","type":"group","z":"7cbab40455148818","name":"Select location","style":{"label":true},"nodes":["6d13cb98d3a5e7e5","10549f2bf19d2c26","85eec4abb03aed2c","4c4910cb28922165","815aae0ecc4dcf74","2d6158161566d46c","f82d955b78f722fb","a95f216608ee4277","466c94fc2dd0ebdc","9fb8b4ca7888a91a","d86a822e247e1ab6","035e652b043062ee","f6d2132f7f890273"],"x":14,"y":19,"w":852,"h":202},{"id":"cd3ae270cc151264","type":"junction","z":"7cbab40455148818","g":"7d4dc1d92148e514","x":500,"y":320,"wires":[["7fe54a223140edd1","e72095c3c957fa28","c1534aab37af0fe7","89c27384c32f3f40"]]},{"id":"422bb58242222c78","type":"junction","z":"7cbab40455148818","g":"4a3b7fdba3b765f5","x":40,"y":460,"wires":[["49639fb6d42fd0c4","cf094d9bcd67e11d","0f338e9e6035dc28"]]},{"id":"936c716a94a76d08","type":"junction","z":"7cbab40455148818","g":"c8ded7141c7ee18e","x":40,"y":300,"wires":[["931667020aadabb8","b786cdc988aa4d18"]]},{"id":"035e652b043062ee","type":"junction","z":"7cbab40455148818","g":"e63e8134815e9780","x":240,"y":180,"wires":[["6d13cb98d3a5e7e5","10549f2bf19d2c26","9fb8b4ca7888a91a","85eec4abb03aed2c"]]},{"id":"d86a822e247e1ab6","type":"junction","z":"7cbab40455148818","g":"e63e8134815e9780","x":640,"y":180,"wires":[["035e652b043062ee","815aae0ecc4dcf74"]]},{"id":"de933fb7d9913984","type":"ui-text","z":"7cbab40455148818","g":"4a3b7fdba3b765f5","group":"1a9825529c80e354","order":1,"width":"3","height":"1","name":"","label":"Chosen location","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":340,"y":420,"wires":[]},{"id":"49639fb6d42fd0c4","type":"change","z":"7cbab40455148818","g":"4a3b7fdba3b765f5","name":"Location Name","rules":[{"t":"move","p":"location.name","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":420,"wires":[["de933fb7d9913984"]]},{"id":"b786cdc988aa4d18","type":"link call","z":"7cbab40455148818","g":"c8ded7141c7ee18e","name":"GetForecast","links":["b2ed74cc5a434824"],"linkType":"static","timeout":"30","x":170,"y":320,"wires":[["cd3ae270cc151264","422bb58242222c78"]]},{"id":"51f434a5cae8205f","type":"ui-gauge","z":"7cbab40455148818","g":"7d4dc1d92148e514","name":"","group":"0f521086ccb8d932","order":2,"width":"2","height":"2","gtype":"gauge-34","gstyle":"needle","title":"Pressure","units":"hPa","icon":"","prefix":"","suffix":"","segments":[{"from":"920","color":"#a8f5ff"},{"from":"953","color":"#55dbec"},{"from":"986","color":"#53b4fd"},{"from":"1020","color":"#2397d1"}],"min":"920","max":"1050","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":760,"y":320,"wires":[]},{"id":"c1534aab37af0fe7","type":"change","z":"7cbab40455148818","g":"7d4dc1d92148e514","name":"Pressure","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.air_pressure_at_sea_level","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":320,"wires":[["51f434a5cae8205f"]]},{"id":"e72095c3c957fa28","type":"change","z":"7cbab40455148818","g":"7d4dc1d92148e514","name":"Temp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.air_temperature","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":280,"wires":[["5924dba7ae857d85"]]},{"id":"5924dba7ae857d85","type":"ui-gauge","z":"7cbab40455148818","g":"7d4dc1d92148e514","name":"","group":"0f521086ccb8d932","order":1,"width":"2","height":"2","gtype":"gauge-34","gstyle":"needle","title":"Temperature","units":"°C","icon":"","prefix":"","suffix":"","segments":[{"from":"-20","color":"#a8f5ff"},{"from":"0","color":"#f4fe43"},{"from":"20","color":"#52fe6b"},{"from":"40","color":"#ff5959"}],"min":"-20","max":"50","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":770,"y":280,"wires":[]},{"id":"7fe54a223140edd1","type":"change","z":"7cbab40455148818","g":"7d4dc1d92148e514","name":"Humidity","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.relative_humidity","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":360,"wires":[["76f76fb5bbf14592"]]},{"id":"76f76fb5bbf14592","type":"ui-gauge","z":"7cbab40455148818","g":"7d4dc1d92148e514","name":"","group":"0f521086ccb8d932","order":3,"width":"2","height":"2","gtype":"gauge-34","gstyle":"needle","title":"Humidity","units":"%","icon":"","prefix":"","suffix":"","segments":[{"from":"0","color":"#ff5959"},{"from":"23","color":"#52fe6b"},{"from":"56","color":"#f4fe43"},{"from":"80","color":"#a8f5ff"}],"min":"0","max":"100","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":760,"y":360,"wires":[]},{"id":"931667020aadabb8","type":"link call","z":"7cbab40455148818","g":"c8ded7141c7ee18e","name":"Getmeteogram","links":["d42ac7c1b5719dd1"],"linkType":"static","timeout":"30","x":180,"y":280,"wires":[["b1220308c3ee3924"]]},{"id":"b1220308c3ee3924","type":"ui-template","z":"7cbab40455148818","g":"c8ded7141c7ee18e","group":"7d68db5e2078459f","page":"","ui":"","name":"Meteogram","order":1,"width":0,"height":0,"head":"","format":"<template>\n    <p>{{msg.payload}}</p>\n    <div class=\"meteogram\">\n        <img :src=\"`/${msg.payload}`\" alt=\"Check httpStatic in settings.js\" style =\"max-width:100%; height:auto; border: 1px solid silver;\">\n    </div>\n</template>\n","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":370,"y":280,"wires":[[]]},{"id":"89c27384c32f3f40","type":"function","z":"7cbab40455148818","g":"7d4dc1d92148e514","name":"Massage","func":"let myarray = []\n\nfunction myFunction(value, index, array) {\n    //node.warn (value);\n    if (value.data.next_1_hours) { // let's only use hourly forecast\n        const ts = dayjs(value.time)\n        const dddhhmm = ts.format(\"ddd HH:mm\")\n        const obj = {\n            \"dddhhmm\": dddhhmm,\n            \"timestamp\": value.time,\n            \"temperature\": value.data.instant.details.air_temperature,\n            \"pressure\": value.data.instant.details.air_pressure_at_sea_level,\n            \"humidity\": value.data.instant.details.relative_humidity,\n            \"rain\": (value.data.next_1_hours) ? \n               value.data.next_1_hours.details.precipitation_amount : (value.data.next_6_hours) ?\n               value.data.next_6_hours.details.precipitation_amount : 0\n        }\n        myarray.push (obj)\n    }   \n} \nmsg.payload.timeseries.forEach (myFunction)\nmsg.payload = myarray\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"dayjs","module":"dayjs"}],"x":600,"y":420,"wires":[["0f78871f5accc1be","d95533dff0506135"]]},{"id":"0f78871f5accc1be","type":"ui-chart","z":"7cbab40455148818","g":"7d4dc1d92148e514","group":"0f521086ccb8d932","name":"","label":"Temperature","order":4,"chartType":"line","category":"Temperature","categoryType":"str","xAxisLabel":"","xAxisProperty":"timestamp","xAxisPropertyType":"property","xAxisType":"time","xAxisFormat":"","xAxisFormatType":"ccc HH:mm","xmin":"","xmax":"","yAxisLabel":" °C","yAxisProperty":"temperature","yAxisPropertyType":"property","ymin":"","ymax":"","bins":10,"action":"replace","stackSeries":false,"pointShape":"false","pointRadius":"2","showLegend":true,"removeOlder":"4","removeOlderUnit":"604800","removeOlderPoints":"1000","colors":["#0095ff","#ff0000","#ff7f0e","#2ca02c","#a347e1","#d62728","#ff9896","#9467bd","#c5b0d5"],"textColor":["#666666"],"textColorDefault":true,"gridColor":["#e5e5e5"],"gridColorDefault":true,"width":"6","height":"4","className":"","interpolation":"bezier","x":770,"y":400,"wires":[[]]},{"id":"d95533dff0506135","type":"ui-chart","z":"7cbab40455148818","g":"7d4dc1d92148e514","group":"0f521086ccb8d932","name":"","label":"Rain","order":5,"chartType":"bar","category":"Rain","categoryType":"str","xAxisLabel":"","xAxisProperty":"dddhhmm","xAxisPropertyType":"property","xAxisType":"category","xAxisFormat":"","xAxisFormatType":"ccc HH:mm","xmin":"","xmax":"","yAxisLabel":"mm","yAxisProperty":"rain","yAxisPropertyType":"property","ymin":"","ymax":"","bins":10,"action":"replace","stackSeries":false,"pointShape":"false","pointRadius":"2","showLegend":true,"removeOlder":"4","removeOlderUnit":"604800","removeOlderPoints":"1000","colors":["#0095ff","#ff0000","#ff7f0e","#2ca02c","#a347e1","#d62728","#ff9896","#9467bd","#c5b0d5"],"textColor":["#666666"],"textColorDefault":true,"gridColor":["#e5e5e5"],"gridColorDefault":true,"width":"6","height":"4","className":"","interpolation":"bezier","x":750,"y":440,"wires":[[]]},{"id":"cf094d9bcd67e11d","type":"function","z":"7cbab40455148818","g":"4a3b7fdba3b765f5","name":"Format dates","func":"let ts = dayjs(msg.payload.meta.updated_at)\nmsg.payload.updated = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.cached)\nmsg.payload.cached = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.expires)\nmsg.payload.expires = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.modified)\nmsg.payload.modified = ts.format(\"ddd HH:mm:ss\")\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"dayjs","module":"dayjs"}],"x":150,"y":500,"wires":[["5fe578a8840fdf04"]]},{"id":"5fe578a8840fdf04","type":"ui-table","z":"7cbab40455148818","g":"4a3b7fdba3b765f5","group":"1a9825529c80e354","name":"","label":"Metadata","order":3,"width":"6","height":"1","maxrows":"0","passthru":false,"autocols":false,"showSearch":false,"selectionType":"none","columns":[{"title":"Updated","key":"updated","keyType":"key","type":"text","width":"","align":"start"},{"title":"Cached","key":"cached","keyType":"key","type":"text","width":"","align":"start"},{"title":"Expires","key":"expires","keyType":"key","type":"text","width":"","align":"start"},{"title":"Modified","key":"modified","keyType":"key","type":"text","width":"","align":"start"}],"mobileBreakpoint":"sm","mobileBreakpointType":"defaults","action":"replace","x":320,"y":500,"wires":[[]]},{"id":"6d13cb98d3a5e7e5","type":"ui-slider","z":"7cbab40455148818","g":"e63e8134815e9780","group":"c8ef9086d862df90","name":"","label":"Slider","tooltip":"","order":4,"width":"4","height":"1","passthru":false,"outs":"all","topic":"slider","topicType":"str","thumbLabel":"false","showTicks":"always","min":0,"max":"5","step":1,"className":"","iconPrepend":"","iconAppend":"","color":"","colorTrack":"","colorThumb":"","showTextField":false,"x":350,"y":180,"wires":[["a95f216608ee4277"]]},{"id":"10549f2bf19d2c26","type":"ui-radio-group","z":"7cbab40455148818","g":"e63e8134815e9780","group":"c8ef9086d862df90","name":"","label":"Radio Group","order":3,"width":"2","height":"1","columns":1,"passthru":false,"options":[],"payload":"","topic":"radio","topicType":"str","className":"","x":370,"y":140,"wires":[["d86a822e247e1ab6"]]},{"id":"85eec4abb03aed2c","type":"ui-button-group","z":"7cbab40455148818","g":"e63e8134815e9780","name":"","group":"c8ef9086d862df90","order":1,"width":"6","height":"1","label":"Button Group","className":"","rounded":true,"useThemeColors":true,"passthru":false,"options":[{"label":"","icon":"","value":"option_0","valueType":"str","color":"#009933"},{"label":"","icon":"","value":"option_1","valueType":"str","color":"#999999"}],"topic":"button","topicType":"str","x":370,"y":60,"wires":[["d86a822e247e1ab6"]]},{"id":"4c4910cb28922165","type":"link in","z":"7cbab40455148818","g":"e63e8134815e9780","name":"locations","links":["2e3967a1027bc4d3"],"x":100,"y":100,"wires":[["f6d2132f7f890273"]],"l":true},{"id":"815aae0ecc4dcf74","type":"function","z":"7cbab40455148818","g":"e63e8134815e9780","name":"Interpret","func":"const places = flow.get(\"places\") ?? []\nmsg.payload = places[msg.payload]\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":180,"wires":[["f82d955b78f722fb","936c716a94a76d08"]]},{"id":"2d6158161566d46c","type":"ui-text","z":"7cbab40455148818","g":"e63e8134815e9780","group":"c8ef9086d862df90","order":5,"width":"2","height":"1","name":"","label":"Selected","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":780,"y":60,"wires":[]},{"id":"f82d955b78f722fb","type":"change","z":"7cbab40455148818","g":"e63e8134815e9780","name":"name","rules":[{"t":"move","p":"payload.name","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":60,"wires":[["2d6158161566d46c"]]},{"id":"a95f216608ee4277","type":"trigger","z":"7cbab40455148818","g":"e63e8134815e9780","name":"slow","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"500","extend":true,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":470,"y":180,"wires":[["d86a822e247e1ab6"]]},{"id":"0f338e9e6035dc28","type":"change","z":"7cbab40455148818","g":"4a3b7fdba3b765f5","name":"From Cache?","rules":[{"t":"move","p":"payload.fromcache","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":460,"wires":[["b50876501a9e8e02"]]},{"id":"b50876501a9e8e02","type":"ui-text","z":"7cbab40455148818","g":"4a3b7fdba3b765f5","group":"1a9825529c80e354","order":2,"width":"3","height":"1","name":"","label":"Served from cache","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":350,"y":460,"wires":[]},{"id":"466c94fc2dd0ebdc","type":"ui-template","z":"7cbab40455148818","g":"e63e8134815e9780","group":"","page":"0c1609bc6c95c49a","ui":"","name":"Show widget borders","order":0,"width":0,"height":0,"head":"","format":".nrdb-ui-widget {\n    border: 1px solid yellowgreen;\n}\n.nrdb-ui-group {\n    border: 1px solid crimson;\n}","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"page:style","className":"","x":140,"y":60,"wires":[[]]},{"id":"9fb8b4ca7888a91a","type":"ui-dropdown","z":"7cbab40455148818","g":"e63e8134815e9780","group":"c8ef9086d862df90","name":"","label":"Dropdown","tooltip":"","order":2,"width":"2","height":"1","passthru":false,"multiple":false,"chips":false,"clearable":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"drop","topicType":"str","className":"","typeIsComboBox":true,"msgTrigger":"onChange","x":370,"y":100,"wires":[["d86a822e247e1ab6"]]},{"id":"f6d2132f7f890273","type":"function","z":"7cbab40455148818","g":"e63e8134815e9780","name":"Setup locations","func":"const places = msg.payload\nflow.set (\"places\", places)\n\nlet buttonoptions = []\nplaces.forEach(function (item, index) { \n    buttonoptions.push({ \"dropdown\": \"Location\", \"label\": item.name, \"value\": index, \"icon\": item.icon }) \n});\nlet buttonmsg = { \"ui_update\": { \"options\": buttonoptions, \"max\": places.length - 1 } } // max is for length of slider\n\nreturn buttonmsg","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":120,"y":140,"wires":[["035e652b043062ee"]]},{"id":"1a9825529c80e354","type":"ui-group","name":"Stats","page":"0c1609bc6c95c49a","width":"6","height":1,"order":3,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"0f521086ccb8d932","type":"ui-group","name":"Weather","page":"0c1609bc6c95c49a","width":"6","height":1,"order":4,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"7d68db5e2078459f","type":"ui-group","name":"Meteogram","page":"0c1609bc6c95c49a","width":"5","height":1,"order":2,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"c8ef9086d862df90","type":"ui-group","name":"Select the location","page":"0c1609bc6c95c49a","width":"6","height":1,"order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"0c1609bc6c95c49a","type":"ui-page","name":"Weather - Grid layout","ui":"d45641ed6d39fea1","path":"/grid","icon":"home","layout":"grid","theme":"0d92c765bfad87e6","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":1,"className":"","visible":"true","disabled":"false"},{"id":"d45641ed6d39fea1","type":"ui-base","name":"This is my ui-base","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":false,"notificationDisplayTime":5,"showDisconnectNotification":false},{"id":"0d92c765bfad87e6","type":"ui-theme","name":"Basic Blue Theme","colors":{"surface":"#4d58ff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"2px","density":"default"}}]
No 3 Fixed layout
[{"id":"07104c0faaba71f1","type":"tab","label":"Fixed layout","disabled":false,"info":"","env":[]},{"id":"6642964c01994ab8","type":"group","z":"07104c0faaba71f1","name":"Current Weather","style":{"label":true},"nodes":["2ed0af69367af27e","f90c653f7f9aafa8","569c61aa2557bac1","5a9d24c7015a7523","72825218b36076f8","c6f11625aeba7b41","f67edea4aa1a88cb","b8a268f203894556","5d56f536921119fa","327270026cb0ae75"],"x":474,"y":239,"w":392,"h":242},{"id":"ba00f39e64df084d","type":"group","z":"07104c0faaba71f1","name":"Statistics","style":{"label":true},"nodes":["24888b4032690773","084c0a5ae6df0215","d8c994a7ab2ed555","3c66082719f8528e","df8b1429b6644146","9b22db9d9f7c6a59","8b8f64265a728050"],"x":14,"y":379,"w":452,"h":162},{"id":"59abfa23e0375a51","type":"group","z":"07104c0faaba71f1","name":"Select location","style":{"label":true},"nodes":["bbbbdc2c327aa5ac","4c7dde6a2b2786e4","24975c1647d94573","301624436e7afd02","9f3d6e25bce155ff","44816aa23b0bafb6","0cd55f5a889415f9","c7acfb67776f7448","3cc77b34a8725a32","d564166768c9f13c","d988b3c856516b12","83e8db138daf8754","c8c66d7a123622b9"],"x":14,"y":19,"w":852,"h":202},{"id":"7f2f7f614c10192f","type":"group","z":"07104c0faaba71f1","name":"Meteogram","style":{"label":true},"nodes":["fa635714d506351b","4adfdfa631a16df7","e2dfabe057de7368","e9b5b951606c945c"],"x":14,"y":239,"w":452,"h":122},{"id":"f67edea4aa1a88cb","type":"junction","z":"07104c0faaba71f1","g":"6642964c01994ab8","x":500,"y":320,"wires":[["72825218b36076f8","569c61aa2557bac1","f90c653f7f9aafa8","b8a268f203894556"]]},{"id":"d8c994a7ab2ed555","type":"junction","z":"07104c0faaba71f1","g":"ba00f39e64df084d","x":40,"y":460,"wires":[["084c0a5ae6df0215","3c66082719f8528e","9b22db9d9f7c6a59"]]},{"id":"e9b5b951606c945c","type":"junction","z":"07104c0faaba71f1","g":"7f2f7f614c10192f","x":40,"y":300,"wires":[["fa635714d506351b","e2dfabe057de7368"]]},{"id":"83e8db138daf8754","type":"junction","z":"07104c0faaba71f1","g":"59abfa23e0375a51","x":240,"y":180,"wires":[["24975c1647d94573","d564166768c9f13c","4c7dde6a2b2786e4","bbbbdc2c327aa5ac"]]},{"id":"c8c66d7a123622b9","type":"junction","z":"07104c0faaba71f1","g":"59abfa23e0375a51","x":640,"y":180,"wires":[["9f3d6e25bce155ff","83e8db138daf8754"]]},{"id":"2ed0af69367af27e","type":"ui-gauge","z":"07104c0faaba71f1","g":"6642964c01994ab8","name":"","group":"e920a54a04c7a9b8","order":3,"width":"2","height":"2","gtype":"gauge-34","gstyle":"needle","title":"Pressure","units":"hPa","icon":"","prefix":"","suffix":"","segments":[{"from":"920","color":"#a8f5ff"},{"from":"953","color":"#55dbec"},{"from":"986","color":"#53b4fd"},{"from":"1020","color":"#2397d1"}],"min":"920","max":"1050","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":760,"y":320,"wires":[]},{"id":"f90c653f7f9aafa8","type":"change","z":"07104c0faaba71f1","g":"6642964c01994ab8","name":"Pressure","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.air_pressure_at_sea_level","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":320,"wires":[["2ed0af69367af27e"]]},{"id":"569c61aa2557bac1","type":"change","z":"07104c0faaba71f1","g":"6642964c01994ab8","name":"Temp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.air_temperature","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":280,"wires":[["5a9d24c7015a7523"]]},{"id":"5a9d24c7015a7523","type":"ui-gauge","z":"07104c0faaba71f1","g":"6642964c01994ab8","name":"","group":"e920a54a04c7a9b8","order":1,"width":"2","height":"2","gtype":"gauge-34","gstyle":"needle","title":"Temperature","units":"°C","icon":"","prefix":"","suffix":"","segments":[{"from":"-20","color":"#a8f5ff"},{"from":"0","color":"#f4fe43"},{"from":"20","color":"#52fe6b"},{"from":"40","color":"#ff5959"}],"min":"-20","max":"50","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":770,"y":280,"wires":[]},{"id":"72825218b36076f8","type":"change","z":"07104c0faaba71f1","g":"6642964c01994ab8","name":"Humidity","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.relative_humidity","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":360,"wires":[["c6f11625aeba7b41"]]},{"id":"c6f11625aeba7b41","type":"ui-gauge","z":"07104c0faaba71f1","g":"6642964c01994ab8","name":"","group":"e920a54a04c7a9b8","order":2,"width":"2","height":"2","gtype":"gauge-34","gstyle":"needle","title":"Humidity","units":"%","icon":"","prefix":"","suffix":"","segments":[{"from":"0","color":"#ff5959"},{"from":"23","color":"#52fe6b"},{"from":"56","color":"#f4fe43"},{"from":"80","color":"#a8f5ff"}],"min":"0","max":"100","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":760,"y":360,"wires":[]},{"id":"b8a268f203894556","type":"function","z":"07104c0faaba71f1","g":"6642964c01994ab8","name":"Massage","func":"let myarray = []\n\nfunction myFunction(value, index, array) {\n    //node.warn (value);\n    if (value.data.next_1_hours) { // let's only use hourly forecast\n        const ts = dayjs(value.time)\n        const dddhhmm = ts.format(\"ddd HH:mm\")\n        const obj = {\n            \"dddhhmm\": dddhhmm,\n            \"timestamp\": value.time,\n            \"temperature\": value.data.instant.details.air_temperature,\n            \"pressure\": value.data.instant.details.air_pressure_at_sea_level,\n            \"humidity\": value.data.instant.details.relative_humidity,\n            \"rain\": (value.data.next_1_hours) ? \n               value.data.next_1_hours.details.precipitation_amount : (value.data.next_6_hours) ?\n               value.data.next_6_hours.details.precipitation_amount : 0\n        }\n        myarray.push (obj)\n    }   \n} \nmsg.payload.timeseries.forEach (myFunction)\nmsg.payload = myarray\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"dayjs","module":"dayjs"}],"x":600,"y":420,"wires":[["327270026cb0ae75","5d56f536921119fa"]]},{"id":"5d56f536921119fa","type":"ui-chart","z":"07104c0faaba71f1","g":"6642964c01994ab8","group":"e920a54a04c7a9b8","name":"","label":"Rain","order":5,"chartType":"bar","category":"Rain","categoryType":"str","xAxisLabel":"","xAxisProperty":"dddhhmm","xAxisPropertyType":"property","xAxisType":"category","xAxisFormat":"","xAxisFormatType":"ccc HH:mm","xmin":"","xmax":"","yAxisLabel":"mm","yAxisProperty":"rain","yAxisPropertyType":"property","ymin":"","ymax":"","bins":10,"action":"replace","stackSeries":false,"pointShape":"false","pointRadius":"2","showLegend":true,"removeOlder":"4","removeOlderUnit":"604800","removeOlderPoints":"1000","colors":["#0095ff","#ff0000","#ff7f0e","#2ca02c","#a347e1","#d62728","#ff9896","#9467bd","#c5b0d5"],"textColor":["#666666"],"textColorDefault":true,"gridColor":["#e5e5e5"],"gridColorDefault":true,"width":"6","height":"4","className":"","interpolation":"bezier","x":750,"y":440,"wires":[[]]},{"id":"327270026cb0ae75","type":"ui-chart","z":"07104c0faaba71f1","g":"6642964c01994ab8","group":"e920a54a04c7a9b8","name":"","label":"Temperature","order":4,"chartType":"line","category":"Temperature","categoryType":"str","xAxisLabel":"","xAxisProperty":"timestamp","xAxisPropertyType":"property","xAxisType":"time","xAxisFormat":"","xAxisFormatType":"ccc HH:mm","xmin":"","xmax":"","yAxisLabel":" °C","yAxisProperty":"temperature","yAxisPropertyType":"property","ymin":"","ymax":"","bins":10,"action":"replace","stackSeries":false,"pointShape":"false","pointRadius":"2","showLegend":true,"removeOlder":"4","removeOlderUnit":"604800","removeOlderPoints":"1000","colors":["#0095ff","#ff0000","#ff7f0e","#2ca02c","#a347e1","#d62728","#ff9896","#9467bd","#c5b0d5"],"textColor":["#666666"],"textColorDefault":true,"gridColor":["#e5e5e5"],"gridColorDefault":true,"width":"6","height":"4","className":"","interpolation":"bezier","x":770,"y":400,"wires":[[]]},{"id":"24888b4032690773","type":"ui-text","z":"07104c0faaba71f1","g":"ba00f39e64df084d","group":"802a65fa185075ed","order":1,"width":"3","height":"1","name":"","label":"Chosen location","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":340,"y":420,"wires":[]},{"id":"084c0a5ae6df0215","type":"change","z":"07104c0faaba71f1","g":"ba00f39e64df084d","name":"Location Name","rules":[{"t":"move","p":"location.name","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":420,"wires":[["24888b4032690773"]]},{"id":"3c66082719f8528e","type":"function","z":"07104c0faaba71f1","g":"ba00f39e64df084d","name":"Format dates","func":"let ts = dayjs(msg.payload.meta.updated_at)\nmsg.payload.updated = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.cached)\nmsg.payload.cached = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.expires)\nmsg.payload.expires = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.modified)\nmsg.payload.modified = ts.format(\"ddd HH:mm:ss\")\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"dayjs","module":"dayjs"}],"x":150,"y":500,"wires":[["df8b1429b6644146"]]},{"id":"df8b1429b6644146","type":"ui-table","z":"07104c0faaba71f1","g":"ba00f39e64df084d","group":"802a65fa185075ed","name":"","label":"Metadata","order":3,"width":"6","height":"1","maxrows":"0","passthru":false,"autocols":false,"showSearch":false,"selectionType":"none","columns":[{"title":"Updated","key":"updated","keyType":"key","type":"text","width":"","align":"start"},{"title":"Cached","key":"cached","keyType":"key","type":"text","width":"","align":"start"},{"title":"Expires","key":"expires","keyType":"key","type":"text","width":"","align":"start"},{"title":"Modified","key":"modified","keyType":"key","type":"text","width":"","align":"start"}],"mobileBreakpoint":"sm","mobileBreakpointType":"defaults","action":"replace","x":320,"y":500,"wires":[[]]},{"id":"9b22db9d9f7c6a59","type":"change","z":"07104c0faaba71f1","g":"ba00f39e64df084d","name":"From Cache?","rules":[{"t":"move","p":"payload.fromcache","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":460,"wires":[["8b8f64265a728050"]]},{"id":"8b8f64265a728050","type":"ui-text","z":"07104c0faaba71f1","g":"ba00f39e64df084d","group":"802a65fa185075ed","order":2,"width":"3","height":"1","name":"","label":"Served from cache","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":350,"y":460,"wires":[]},{"id":"bbbbdc2c327aa5ac","type":"ui-slider","z":"07104c0faaba71f1","g":"59abfa23e0375a51","group":"731dff7b103557cb","name":"","label":"Slider","tooltip":"","order":4,"width":"4","height":"1","passthru":false,"outs":"all","topic":"slider","topicType":"str","thumbLabel":"false","showTicks":"always","min":0,"max":"5","step":1,"className":"","iconPrepend":"","iconAppend":"","color":"","colorTrack":"","colorThumb":"","showTextField":false,"x":350,"y":180,"wires":[["c7acfb67776f7448"]]},{"id":"4c7dde6a2b2786e4","type":"ui-radio-group","z":"07104c0faaba71f1","g":"59abfa23e0375a51","group":"731dff7b103557cb","name":"","label":"Radio Group","order":3,"width":"2","height":"1","columns":1,"passthru":false,"options":[],"payload":"","topic":"radio","topicType":"str","className":"","x":370,"y":140,"wires":[["c8c66d7a123622b9"]]},{"id":"24975c1647d94573","type":"ui-button-group","z":"07104c0faaba71f1","g":"59abfa23e0375a51","name":"","group":"731dff7b103557cb","order":1,"width":"6","height":"1","label":"Button Group","className":"","rounded":true,"useThemeColors":true,"passthru":false,"options":[{"label":"","icon":"","value":"option_0","valueType":"str","color":"#009933"},{"label":"","icon":"","value":"option_1","valueType":"str","color":"#999999"}],"topic":"button","topicType":"str","x":370,"y":60,"wires":[["c8c66d7a123622b9"]]},{"id":"301624436e7afd02","type":"link in","z":"07104c0faaba71f1","g":"59abfa23e0375a51","name":"locations","links":["2e3967a1027bc4d3"],"x":100,"y":100,"wires":[["d988b3c856516b12"]],"l":true},{"id":"9f3d6e25bce155ff","type":"function","z":"07104c0faaba71f1","g":"59abfa23e0375a51","name":"Interpret","func":"const places = flow.get(\"places\") ?? []\nmsg.payload = places[msg.payload]\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":180,"wires":[["0cd55f5a889415f9","e9b5b951606c945c"]]},{"id":"44816aa23b0bafb6","type":"ui-text","z":"07104c0faaba71f1","g":"59abfa23e0375a51","group":"731dff7b103557cb","order":5,"width":"2","height":"1","name":"","label":"Selected","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":780,"y":60,"wires":[]},{"id":"0cd55f5a889415f9","type":"change","z":"07104c0faaba71f1","g":"59abfa23e0375a51","name":"name","rules":[{"t":"move","p":"payload.name","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":60,"wires":[["44816aa23b0bafb6"]]},{"id":"c7acfb67776f7448","type":"trigger","z":"07104c0faaba71f1","g":"59abfa23e0375a51","name":"slow","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"500","extend":true,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":470,"y":180,"wires":[["c8c66d7a123622b9"]]},{"id":"3cc77b34a8725a32","type":"ui-template","z":"07104c0faaba71f1","g":"59abfa23e0375a51","group":"","page":"9c67f55259e53c66","ui":"","name":"Show widget borders","order":0,"width":0,"height":0,"head":"","format":".nrdb-ui-widget {\n    border: 1px solid yellowgreen;\n}\n.nrdb-ui-group {\n    border: 1px solid crimson;\n}","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"page:style","className":"","x":140,"y":60,"wires":[[]]},{"id":"fa635714d506351b","type":"link call","z":"07104c0faaba71f1","g":"7f2f7f614c10192f","name":"Getmeteogram","links":["d42ac7c1b5719dd1"],"linkType":"static","timeout":"30","x":180,"y":280,"wires":[["4adfdfa631a16df7"]]},{"id":"4adfdfa631a16df7","type":"ui-template","z":"07104c0faaba71f1","g":"7f2f7f614c10192f","group":"6c4c31a36edaa583","page":"","ui":"","name":"Meteogram","order":1,"width":"0","height":"0","head":"","format":"<template>\n    <p>{{msg.payload}}</p>\n    <div class=\"meteogram\">\n        <img :src=\"`/${msg.payload}`\" alt=\"Check httpStatic in settings.js\" style =\"max-width:100%; height:auto; border: 1px solid silver;\">\n    </div>\n</template>\n","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":370,"y":280,"wires":[[]]},{"id":"e2dfabe057de7368","type":"link call","z":"07104c0faaba71f1","g":"7f2f7f614c10192f","name":"GetForecast","links":["b2ed74cc5a434824"],"linkType":"static","timeout":"30","x":170,"y":320,"wires":[["f67edea4aa1a88cb","d8c994a7ab2ed555"]]},{"id":"d564166768c9f13c","type":"ui-dropdown","z":"07104c0faaba71f1","g":"59abfa23e0375a51","group":"731dff7b103557cb","name":"","label":"Dropdown","tooltip":"","order":2,"width":"2","height":"1","passthru":false,"multiple":false,"chips":false,"clearable":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"drop","topicType":"str","className":"","typeIsComboBox":true,"msgTrigger":"onChange","x":370,"y":100,"wires":[["c8c66d7a123622b9"]]},{"id":"d988b3c856516b12","type":"function","z":"07104c0faaba71f1","g":"59abfa23e0375a51","name":"Setup locations","func":"const places = msg.payload\nflow.set (\"places\", places)\n\nlet buttonoptions = []\nplaces.forEach(function (item, index) { \n    buttonoptions.push({ \"dropdown\": \"Location\", \"label\": item.name, \"value\": index, \"icon\": item.icon }) \n});\nlet buttonmsg = { \"ui_update\": { \"options\": buttonoptions, \"max\": places.length - 1 } } // max is for length of slider\nreturn buttonmsg","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":120,"y":140,"wires":[["83e8db138daf8754"]]},{"id":"e920a54a04c7a9b8","type":"ui-group","name":"Weather","page":"9c67f55259e53c66","width":"6","height":1,"order":4,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"802a65fa185075ed","type":"ui-group","name":"Stats","page":"9c67f55259e53c66","width":"6","height":1,"order":3,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"731dff7b103557cb","type":"ui-group","name":"Selection","page":"9c67f55259e53c66","width":"7","height":1,"order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"9c67f55259e53c66","type":"ui-page","name":"Weather - Fixed layout","ui":"d45641ed6d39fea1","path":"/fixed","icon":"home","layout":"flex","theme":"0d92c765bfad87e6","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":2,"className":"","visible":true,"disabled":false},{"id":"6c4c31a36edaa583","type":"ui-group","name":"Meteogram","page":"9c67f55259e53c66","width":"5","height":1,"order":2,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"d45641ed6d39fea1","type":"ui-base","name":"This is my ui-base","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":false,"notificationDisplayTime":5,"showDisconnectNotification":false},{"id":"0d92c765bfad87e6","type":"ui-theme","name":"Basic Blue Theme","colors":{"surface":"#4d58ff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"2px","density":"default"}}]
No 4 Notebook layout
[{"id":"7fc0565ec4ec1350","type":"tab","label":"Notebook layout","disabled":false,"info":"","env":[]},{"id":"102eca7d253d1450","type":"group","z":"7fc0565ec4ec1350","name":"Current Weather","style":{"label":true},"nodes":["e20dc549c00e5343","cdd8a59669c7811f","aad7d1cda357d336","7851c28e790aa8ff","30da07912ce9ae27","1372721ecc4061bc","133bbd5c8704a57e","ae604d5bcb76c941","02db6682a9fee4e5","04aa5f57d5b0836d"],"x":474,"y":239,"w":392,"h":242},{"id":"b03b341e714071cf","type":"group","z":"7fc0565ec4ec1350","name":"Statistics","style":{"label":true},"nodes":["aeacc9c6bc6e5b9c","08f33e87eed56a92","cf43394b2bb5238b","62795f5e258d95f2","0a8614ef3e664667","860bef87f6b407df","523fc387a53a7f36"],"x":14,"y":379,"w":452,"h":162},{"id":"f8ca6d24cbbe47e5","type":"group","z":"7fc0565ec4ec1350","name":"Select location","style":{"label":true},"nodes":["70262d099ffc6ac9","acefff2dd2245057","6c6087b2d1527260","eede667125cf087c","1ee2e97052d783f1","913652ebac371084","291fb481de186a25","37abcec67f14f09c","f1eb90049fca6823","374c2805a6d40e8d","c31893f7f81d741c","374e240c561d2c02","95d935fddad15d1e"],"x":14,"y":19,"w":852,"h":202},{"id":"8e4165efb44f45fc","type":"group","z":"7fc0565ec4ec1350","name":"Meteogram","style":{"label":true},"nodes":["cca6ead77acf44f0","0a962c9bd78d26f3","5cdd7c69d0f0d718","ac0ce65834cf7c64"],"x":14,"y":239,"w":452,"h":122},{"id":"133bbd5c8704a57e","type":"junction","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","x":500,"y":320,"wires":[["30da07912ce9ae27","aad7d1cda357d336","cdd8a59669c7811f","ae604d5bcb76c941"]]},{"id":"cf43394b2bb5238b","type":"junction","z":"7fc0565ec4ec1350","g":"b03b341e714071cf","x":40,"y":460,"wires":[["08f33e87eed56a92","62795f5e258d95f2","860bef87f6b407df"]]},{"id":"ac0ce65834cf7c64","type":"junction","z":"7fc0565ec4ec1350","g":"8e4165efb44f45fc","x":40,"y":300,"wires":[["cca6ead77acf44f0","5cdd7c69d0f0d718"]]},{"id":"c31893f7f81d741c","type":"junction","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","x":240,"y":180,"wires":[["6c6087b2d1527260","374c2805a6d40e8d","acefff2dd2245057","70262d099ffc6ac9"]]},{"id":"95d935fddad15d1e","type":"junction","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","x":640,"y":180,"wires":[["1ee2e97052d783f1","c31893f7f81d741c"]]},{"id":"e20dc549c00e5343","type":"ui-gauge","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","name":"","group":"60c975f0af78f739","order":2,"width":"2","height":"2","gtype":"gauge-34","gstyle":"needle","title":"Pressure","units":"hPa","icon":"","prefix":"","suffix":"","segments":[{"from":"920","color":"#a8f5ff"},{"from":"953","color":"#55dbec"},{"from":"986","color":"#53b4fd"},{"from":"1020","color":"#2397d1"}],"min":"920","max":"1050","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":760,"y":320,"wires":[]},{"id":"cdd8a59669c7811f","type":"change","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","name":"Pressure","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.air_pressure_at_sea_level","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":320,"wires":[["e20dc549c00e5343"]]},{"id":"aad7d1cda357d336","type":"change","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","name":"Temp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.air_temperature","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":280,"wires":[["7851c28e790aa8ff"]]},{"id":"7851c28e790aa8ff","type":"ui-gauge","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","name":"","group":"60c975f0af78f739","order":1,"width":"2","height":"2","gtype":"gauge-34","gstyle":"needle","title":"Temperature","units":"°C","icon":"","prefix":"","suffix":"","segments":[{"from":"-20","color":"#a8f5ff"},{"from":"0","color":"#f4fe43"},{"from":"20","color":"#52fe6b"},{"from":"40","color":"#ff5959"}],"min":"-20","max":"50","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":770,"y":280,"wires":[]},{"id":"30da07912ce9ae27","type":"change","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","name":"Humidity","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.relative_humidity","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":360,"wires":[["1372721ecc4061bc"]]},{"id":"1372721ecc4061bc","type":"ui-gauge","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","name":"","group":"60c975f0af78f739","order":3,"width":"2","height":"2","gtype":"gauge-34","gstyle":"needle","title":"Humidity","units":"%","icon":"","prefix":"","suffix":"","segments":[{"from":"0","color":"#ff5959"},{"from":"23","color":"#52fe6b"},{"from":"56","color":"#f4fe43"},{"from":"80","color":"#a8f5ff"}],"min":"0","max":"100","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":760,"y":360,"wires":[]},{"id":"ae604d5bcb76c941","type":"function","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","name":"Massage","func":"let myarray = []\n\nfunction myFunction(value, index, array) {\n    //node.warn (value);\n    if (value.data.next_1_hours) { // let's only use hourly forecast\n        const ts = dayjs(value.time)\n        const dddhhmm = ts.format(\"ddd HH:mm\")\n        const obj = {\n            \"dddhhmm\": dddhhmm,\n            \"timestamp\": value.time,\n            \"temperature\": value.data.instant.details.air_temperature,\n            \"pressure\": value.data.instant.details.air_pressure_at_sea_level,\n            \"humidity\": value.data.instant.details.relative_humidity,\n            \"rain\": (value.data.next_1_hours) ? \n               value.data.next_1_hours.details.precipitation_amount : (value.data.next_6_hours) ?\n               value.data.next_6_hours.details.precipitation_amount : 0\n        }\n        myarray.push (obj)\n    }   \n} \nmsg.payload.timeseries.forEach (myFunction)\nmsg.payload = myarray\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"dayjs","module":"dayjs"}],"x":600,"y":420,"wires":[["04aa5f57d5b0836d","02db6682a9fee4e5"]]},{"id":"02db6682a9fee4e5","type":"ui-chart","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","group":"60c975f0af78f739","name":"","label":"Rain","order":5,"chartType":"bar","category":"Rain","categoryType":"str","xAxisLabel":"","xAxisProperty":"dddhhmm","xAxisPropertyType":"property","xAxisType":"category","xAxisFormat":"","xAxisFormatType":"ccc HH:mm","xmin":"","xmax":"","yAxisLabel":"mm","yAxisProperty":"rain","yAxisPropertyType":"property","ymin":"","ymax":"","bins":10,"action":"replace","stackSeries":false,"pointShape":"false","pointRadius":"2","showLegend":true,"removeOlder":"4","removeOlderUnit":"604800","removeOlderPoints":"1000","colors":["#0095ff","#ff0000","#ff7f0e","#2ca02c","#a347e1","#d62728","#ff9896","#9467bd","#c5b0d5"],"textColor":["#666666"],"textColorDefault":true,"gridColor":["#e5e5e5"],"gridColorDefault":true,"width":"6","height":"4","className":"","interpolation":"bezier","x":750,"y":440,"wires":[[]]},{"id":"04aa5f57d5b0836d","type":"ui-chart","z":"7fc0565ec4ec1350","g":"102eca7d253d1450","group":"60c975f0af78f739","name":"","label":"Temperature","order":4,"chartType":"line","category":"Temperature","categoryType":"str","xAxisLabel":"","xAxisProperty":"timestamp","xAxisPropertyType":"property","xAxisType":"time","xAxisFormat":"","xAxisFormatType":"ccc HH:mm","xmin":"","xmax":"","yAxisLabel":"°C","yAxisProperty":"temperature","yAxisPropertyType":"property","ymin":"","ymax":"","bins":10,"action":"replace","stackSeries":false,"pointShape":"false","pointRadius":"2","showLegend":true,"removeOlder":"4","removeOlderUnit":"604800","removeOlderPoints":"1000","colors":["#0095ff","#ff0000","#ff7f0e","#2ca02c","#a347e1","#d62728","#ff9896","#9467bd","#c5b0d5"],"textColor":["#666666"],"textColorDefault":true,"gridColor":["#e5e5e5"],"gridColorDefault":true,"width":"6","height":"4","className":"","interpolation":"bezier","x":770,"y":400,"wires":[[]]},{"id":"aeacc9c6bc6e5b9c","type":"ui-text","z":"7fc0565ec4ec1350","g":"b03b341e714071cf","group":"611c7b1ed7756b6a","order":1,"width":"2","height":"1","name":"","label":"Chosen location","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":340,"y":420,"wires":[]},{"id":"08f33e87eed56a92","type":"change","z":"7fc0565ec4ec1350","g":"b03b341e714071cf","name":"Location Name","rules":[{"t":"move","p":"location.name","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":420,"wires":[["aeacc9c6bc6e5b9c"]]},{"id":"62795f5e258d95f2","type":"function","z":"7fc0565ec4ec1350","g":"b03b341e714071cf","name":"Format dates","func":"let ts = dayjs(msg.payload.meta.updated_at)\nmsg.payload.updated = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.cached)\nmsg.payload.cached = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.expires)\nmsg.payload.expires = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.modified)\nmsg.payload.modified = ts.format(\"ddd HH:mm:ss\")\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"dayjs","module":"dayjs"}],"x":150,"y":500,"wires":[["0a8614ef3e664667"]]},{"id":"0a8614ef3e664667","type":"ui-table","z":"7fc0565ec4ec1350","g":"b03b341e714071cf","group":"611c7b1ed7756b6a","name":"","label":"Metadata","order":3,"width":"5","height":"1","maxrows":"0","passthru":false,"autocols":false,"showSearch":false,"selectionType":"none","columns":[{"title":"Updated","key":"updated","keyType":"key","type":"text","width":"","align":"start"},{"title":"Cached","key":"cached","keyType":"key","type":"text","width":"","align":"start"},{"title":"Expires","key":"expires","keyType":"key","type":"text","width":"","align":"start"},{"title":"Modified","key":"modified","keyType":"key","type":"text","width":"","align":"start"}],"mobileBreakpoint":"sm","mobileBreakpointType":"defaults","action":"replace","x":320,"y":500,"wires":[[]]},{"id":"860bef87f6b407df","type":"change","z":"7fc0565ec4ec1350","g":"b03b341e714071cf","name":"From Cache?","rules":[{"t":"move","p":"payload.fromcache","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":460,"wires":[["523fc387a53a7f36"]]},{"id":"523fc387a53a7f36","type":"ui-text","z":"7fc0565ec4ec1350","g":"b03b341e714071cf","group":"611c7b1ed7756b6a","order":2,"width":"2","height":"1","name":"","label":"Served from cache","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":350,"y":460,"wires":[]},{"id":"70262d099ffc6ac9","type":"ui-slider","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","group":"a740f7b16e0870cd","name":"","label":"Slider","tooltip":"","order":4,"width":"4","height":"1","passthru":false,"outs":"all","topic":"slider","topicType":"str","thumbLabel":"false","showTicks":"always","min":0,"max":"5","step":1,"className":"","iconPrepend":"","iconAppend":"","color":"","colorTrack":"","colorThumb":"","showTextField":false,"x":350,"y":180,"wires":[["291fb481de186a25"]]},{"id":"acefff2dd2245057","type":"ui-radio-group","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","group":"a740f7b16e0870cd","name":"","label":"Radio Group","order":3,"width":"2","height":"1","columns":1,"passthru":false,"options":[],"payload":"","topic":"radio","topicType":"str","className":"","x":370,"y":140,"wires":[["95d935fddad15d1e"]]},{"id":"6c6087b2d1527260","type":"ui-button-group","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","name":"","group":"a740f7b16e0870cd","order":1,"width":"6","height":"1","label":"Button Group","className":"","rounded":true,"useThemeColors":true,"passthru":false,"options":[{"label":"","icon":"","value":"option_0","valueType":"str","color":"#009933"},{"label":"","icon":"","value":"option_1","valueType":"str","color":"#999999"}],"topic":"button","topicType":"str","x":370,"y":60,"wires":[["95d935fddad15d1e"]]},{"id":"eede667125cf087c","type":"link in","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","name":"locations","links":["2e3967a1027bc4d3"],"x":100,"y":100,"wires":[["f1eb90049fca6823"]],"l":true},{"id":"1ee2e97052d783f1","type":"function","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","name":"Interpret","func":"const places = flow.get(\"places\") ?? []\nmsg.payload = places[msg.payload]\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":180,"wires":[["ac0ce65834cf7c64","374e240c561d2c02"]]},{"id":"913652ebac371084","type":"ui-text","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","group":"a740f7b16e0870cd","order":5,"width":"2","height":"1","name":"","label":"Selected","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":780,"y":60,"wires":[]},{"id":"291fb481de186a25","type":"trigger","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","name":"slow","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"500","extend":true,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":470,"y":180,"wires":[["95d935fddad15d1e"]]},{"id":"37abcec67f14f09c","type":"ui-template","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","group":"","page":"d5e7879820277bb4","ui":"","name":"Show widget borders","order":0,"width":0,"height":0,"head":"","format":".nrdb-ui-widget {\n    border: 1px solid yellowgreen;\n}\n.nrdb-ui-group {\n    border: 1px solid crimson;\n}","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"page:style","className":"","x":140,"y":60,"wires":[[]]},{"id":"cca6ead77acf44f0","type":"link call","z":"7fc0565ec4ec1350","g":"8e4165efb44f45fc","name":"Getmeteogram","links":["d42ac7c1b5719dd1"],"linkType":"static","timeout":"30","x":180,"y":280,"wires":[["0a962c9bd78d26f3"]]},{"id":"0a962c9bd78d26f3","type":"ui-template","z":"7fc0565ec4ec1350","g":"8e4165efb44f45fc","group":"8ac0722956eeaca8","page":"","ui":"","name":"Meteogram","order":1,"width":0,"height":0,"head":"","format":"<template>\n    <p>{{msg.payload}}</p>\n    <div class=\"meteogram\">\n        <img :src=\"`/${msg.payload}`\"  alt=\"Check httpStatic in settings.js\" style =\"max-width:100%; height:auto; border: 1px solid silver;\">\n    </div>\n</template>\n","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":370,"y":280,"wires":[[]]},{"id":"5cdd7c69d0f0d718","type":"link call","z":"7fc0565ec4ec1350","g":"8e4165efb44f45fc","name":"GetForecast","links":["b2ed74cc5a434824"],"linkType":"static","timeout":"30","x":170,"y":320,"wires":[["133bbd5c8704a57e","cf43394b2bb5238b"]]},{"id":"f1eb90049fca6823","type":"function","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","name":"Setup locations","func":"const places = msg.payload\nflow.set (\"places\", places)\n\nlet buttonoptions = []\nplaces.forEach(function (item, index) { \n    buttonoptions.push({ \"dropdown\": \"Location\", \"label\": item.name, \"value\": index, \"icon\": item.icon }) \n});\nlet buttonmsg = { \"ui_update\": { \"options\": buttonoptions, \"max\": places.length - 1 } } // max is for length of slider\n\nreturn buttonmsg","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":120,"y":140,"wires":[["c31893f7f81d741c"]]},{"id":"374c2805a6d40e8d","type":"ui-dropdown","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","group":"a740f7b16e0870cd","name":"","label":"Dropdown","tooltip":"","order":2,"width":"2","height":"1","passthru":false,"multiple":false,"chips":false,"clearable":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"drop","topicType":"str","className":"","typeIsComboBox":true,"msgTrigger":"onChange","x":370,"y":100,"wires":[["95d935fddad15d1e"]]},{"id":"374e240c561d2c02","type":"change","z":"7fc0565ec4ec1350","g":"f8ca6d24cbbe47e5","name":"name","rules":[{"t":"move","p":"payload.name","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":60,"wires":[["913652ebac371084"]]},{"id":"60c975f0af78f739","type":"ui-group","name":"Weather","page":"d5e7879820277bb4","width":"6","height":1,"order":4,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"611c7b1ed7756b6a","type":"ui-group","name":"Stats","page":"d5e7879820277bb4","width":"5","height":1,"order":3,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"a740f7b16e0870cd","type":"ui-group","name":"Selection","page":"d5e7879820277bb4","width":"6","height":1,"order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"d5e7879820277bb4","type":"ui-page","name":"Weather - Notebook","ui":"d45641ed6d39fea1","path":"/notebook","icon":"home","layout":"grid","theme":"0d92c765bfad87e6","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":3,"className":"","visible":"true","disabled":"false"},{"id":"8ac0722956eeaca8","type":"ui-group","name":"Meteogram","page":"d5e7879820277bb4","width":"5","height":1,"order":2,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"d45641ed6d39fea1","type":"ui-base","name":"This is my ui-base","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":false,"notificationDisplayTime":5,"showDisconnectNotification":false},{"id":"0d92c765bfad87e6","type":"ui-theme","name":"Basic Blue Theme","colors":{"surface":"#4d58ff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"2px","density":"default"}}]
No 5 Tabs layout
[{"id":"e185156382741029","type":"tab","label":"Tab layout","disabled":false,"info":"","env":[]},{"id":"0b55d43247ad3511","type":"group","z":"e185156382741029","name":"Current Weather","style":{"label":true},"nodes":["3dd25575012d38fb","020c3f4889557168","f2ed6ace7565ea0b","283369ba0b63a9c1","ac8d3489d41e165e","954d0ed9e80adca1","8b5a870af69e6eb8","081a435bfa73106b","6477a7cf0b7fdcac","15325f1c1fe9df15"],"x":474,"y":239,"w":392,"h":242},{"id":"f50e3ea43f4e79f3","type":"group","z":"e185156382741029","name":"Statistics","style":{"label":true},"nodes":["18524e062bb00296","114257f1a5d1b515","cd7e51f49f3580b7","8ec51bcfd86c10a2","2b581a9639cba067","acf858f7992a62f1","ee20c59b6e135fcc"],"x":14,"y":379,"w":452,"h":162},{"id":"c4b1e262e5c5f7ae","type":"group","z":"e185156382741029","name":"Meteogram","style":{"label":true},"nodes":["62d336cae4d4126b","7fefefa4531004e3","44a02ea31662a7f1","2cb1bf239d2b9e02"],"x":14,"y":239,"w":452,"h":122},{"id":"e691f8bead778534","type":"group","z":"e185156382741029","name":"Select location","style":{"label":true},"nodes":["5782379537035808","4f96c1deb4cb92f9","d27fa0f6a5665828","8fcca52857e4ad81","2e0d87020bd3853d","6f38a339c19ab4fe","927b86f9a7ec8511","3b0226dbc133341d","ddabd25ec5742fcc","6447d43ea61ac710","308b66ba3969e981","6739d3a99001bd4e","d7932b0f1773fdfa"],"x":14,"y":19,"w":852,"h":202},{"id":"8b5a870af69e6eb8","type":"junction","z":"e185156382741029","g":"0b55d43247ad3511","x":500,"y":320,"wires":[["ac8d3489d41e165e","f2ed6ace7565ea0b","020c3f4889557168","081a435bfa73106b"]]},{"id":"cd7e51f49f3580b7","type":"junction","z":"e185156382741029","g":"f50e3ea43f4e79f3","x":40,"y":460,"wires":[["114257f1a5d1b515","8ec51bcfd86c10a2","acf858f7992a62f1"]]},{"id":"2cb1bf239d2b9e02","type":"junction","z":"e185156382741029","g":"c4b1e262e5c5f7ae","x":40,"y":300,"wires":[["62d336cae4d4126b","44a02ea31662a7f1"]]},{"id":"308b66ba3969e981","type":"junction","z":"e185156382741029","g":"e691f8bead778534","x":240,"y":180,"wires":[["d27fa0f6a5665828","4f96c1deb4cb92f9","5782379537035808","d7932b0f1773fdfa"]]},{"id":"6739d3a99001bd4e","type":"junction","z":"e185156382741029","g":"e691f8bead778534","x":640,"y":180,"wires":[["2e0d87020bd3853d","308b66ba3969e981"]]},{"id":"3dd25575012d38fb","type":"ui-gauge","z":"e185156382741029","g":"0b55d43247ad3511","name":"","group":"4d960df950a4fce6","order":2,"width":"1","height":"1","gtype":"gauge-34","gstyle":"needle","title":"Pressure","units":"hPa","icon":"","prefix":"","suffix":"","segments":[{"from":"920","color":"#a8f5ff"},{"from":"953","color":"#55dbec"},{"from":"986","color":"#53b4fd"},{"from":"1020","color":"#2397d1"}],"min":"920","max":"1050","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":760,"y":320,"wires":[]},{"id":"020c3f4889557168","type":"change","z":"e185156382741029","g":"0b55d43247ad3511","name":"Pressure","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.air_pressure_at_sea_level","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":320,"wires":[["3dd25575012d38fb"]]},{"id":"f2ed6ace7565ea0b","type":"change","z":"e185156382741029","g":"0b55d43247ad3511","name":"Temp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.air_temperature","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":280,"wires":[["283369ba0b63a9c1"]]},{"id":"283369ba0b63a9c1","type":"ui-gauge","z":"e185156382741029","g":"0b55d43247ad3511","name":"","group":"4d960df950a4fce6","order":1,"width":"1","height":"1","gtype":"gauge-34","gstyle":"needle","title":"Temperature","units":"°C","icon":"","prefix":"","suffix":"","segments":[{"from":"-20","color":"#a8f5ff"},{"from":"0","color":"#f4fe43"},{"from":"20","color":"#52fe6b"},{"from":"40","color":"#ff5959"}],"min":"-20","max":"50","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":770,"y":280,"wires":[]},{"id":"ac8d3489d41e165e","type":"change","z":"e185156382741029","g":"0b55d43247ad3511","name":"Humidity","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.timeseries[0].data.instant.details.relative_humidity","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":360,"wires":[["954d0ed9e80adca1"]]},{"id":"954d0ed9e80adca1","type":"ui-gauge","z":"e185156382741029","g":"0b55d43247ad3511","name":"","group":"4d960df950a4fce6","order":3,"width":"1","height":"1","gtype":"gauge-34","gstyle":"needle","title":"Humidity","units":"%","icon":"","prefix":"","suffix":"","segments":[{"from":"0","color":"#ff5959"},{"from":"23","color":"#52fe6b"},{"from":"56","color":"#f4fe43"},{"from":"80","color":"#a8f5ff"}],"min":"0","max":"100","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":760,"y":360,"wires":[]},{"id":"081a435bfa73106b","type":"function","z":"e185156382741029","g":"0b55d43247ad3511","name":"Massage","func":"let myarray = []\n\nfunction myFunction(value, index, array) {\n    //node.warn (value);\n    if (value.data.next_1_hours) { // let's only use hourly forecast\n        const ts = dayjs(value.time)\n        const dddhhmm = ts.format(\"ddd HH:mm\")\n        const obj = {\n            \"dddhhmm\": dddhhmm,\n            \"timestamp\": value.time,\n            \"temperature\": value.data.instant.details.air_temperature,\n            \"pressure\": value.data.instant.details.air_pressure_at_sea_level,\n            \"humidity\": value.data.instant.details.relative_humidity,\n            \"rain\": (value.data.next_1_hours) ? \n               value.data.next_1_hours.details.precipitation_amount : (value.data.next_6_hours) ?\n               value.data.next_6_hours.details.precipitation_amount : 0\n        }\n        myarray.push (obj)\n    }   \n} \nmsg.payload.timeseries.forEach (myFunction)\nmsg.payload = myarray\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"dayjs","module":"dayjs"}],"x":600,"y":420,"wires":[["15325f1c1fe9df15","6477a7cf0b7fdcac"]]},{"id":"6477a7cf0b7fdcac","type":"ui-chart","z":"e185156382741029","g":"0b55d43247ad3511","group":"4d960df950a4fce6","name":"","label":"Rain","order":6,"chartType":"bar","category":"Rain","categoryType":"str","xAxisLabel":"","xAxisProperty":"dddhhmm","xAxisPropertyType":"property","xAxisType":"category","xAxisFormat":"","xAxisFormatType":"ccc HH:mm","xmin":"","xmax":"","yAxisLabel":"mm","yAxisProperty":"rain","yAxisPropertyType":"property","ymin":"","ymax":"","bins":10,"action":"replace","stackSeries":false,"pointShape":"false","pointRadius":"2","showLegend":true,"removeOlder":"4","removeOlderUnit":"604800","removeOlderPoints":"1000","colors":["#0095ff","#ff0000","#ff7f0e","#2ca02c","#a347e1","#d62728","#ff9896","#9467bd","#c5b0d5"],"textColor":["#666666"],"textColorDefault":true,"gridColor":["#e5e5e5"],"gridColorDefault":true,"width":"2","height":"5","className":"","interpolation":"bezier","x":750,"y":440,"wires":[[]]},{"id":"15325f1c1fe9df15","type":"ui-chart","z":"e185156382741029","g":"0b55d43247ad3511","group":"4d960df950a4fce6","name":"","label":"Temperature","order":5,"chartType":"line","category":"Temperature","categoryType":"str","xAxisLabel":"","xAxisProperty":"timestamp","xAxisPropertyType":"property","xAxisType":"time","xAxisFormat":"","xAxisFormatType":"ccc HH:mm","xmin":"","xmax":"","yAxisLabel":" °C","yAxisProperty":"temperature","yAxisPropertyType":"property","ymin":"","ymax":"","bins":10,"action":"replace","stackSeries":false,"pointShape":"false","pointRadius":"2","showLegend":true,"removeOlder":"4","removeOlderUnit":"604800","removeOlderPoints":"1000","colors":["#0095ff","#ff0000","#ff7f0e","#2ca02c","#a347e1","#d62728","#ff9896","#9467bd","#c5b0d5"],"textColor":["#666666"],"textColorDefault":true,"gridColor":["#e5e5e5"],"gridColorDefault":true,"width":"2","height":"5","className":"","interpolation":"bezier","x":770,"y":400,"wires":[[]]},{"id":"18524e062bb00296","type":"ui-text","z":"e185156382741029","d":true,"g":"f50e3ea43f4e79f3","group":"bf88c513dcf7e24c","order":1,"width":"1","height":"1","name":"","label":"Chosen location","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":340,"y":420,"wires":[]},{"id":"114257f1a5d1b515","type":"change","z":"e185156382741029","g":"f50e3ea43f4e79f3","name":"Location Name","rules":[{"t":"move","p":"location.name","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":420,"wires":[["18524e062bb00296"]]},{"id":"8ec51bcfd86c10a2","type":"function","z":"e185156382741029","g":"f50e3ea43f4e79f3","name":"Format dates","func":"let ts = dayjs(msg.payload.meta.updated_at)\nmsg.payload.updated = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.cached)\nmsg.payload.cached = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.expires)\nmsg.payload.expires = ts.format(\"ddd HH:mm:ss\")\nts = dayjs(msg.payload.modified)\nmsg.payload.modified = ts.format(\"ddd HH:mm:ss\")\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"dayjs","module":"dayjs"}],"x":150,"y":500,"wires":[["2b581a9639cba067"]]},{"id":"2b581a9639cba067","type":"ui-table","z":"e185156382741029","g":"f50e3ea43f4e79f3","group":"bf88c513dcf7e24c","name":"","label":"Metadata","order":5,"width":"3","height":"1","maxrows":"0","passthru":false,"autocols":false,"showSearch":false,"selectionType":"none","columns":[{"title":"Updated","key":"updated","keyType":"key","type":"text","width":"","align":"start"},{"title":"Cached","key":"cached","keyType":"key","type":"text","width":"","align":"start"},{"title":"Expires","key":"expires","keyType":"key","type":"text","width":"","align":"start"},{"title":"Modified","key":"modified","keyType":"key","type":"text","width":"","align":"start"}],"mobileBreakpoint":"sm","mobileBreakpointType":"defaults","action":"replace","x":320,"y":500,"wires":[[]]},{"id":"acf858f7992a62f1","type":"change","z":"e185156382741029","g":"f50e3ea43f4e79f3","name":"From Cache?","rules":[{"t":"move","p":"payload.fromcache","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":460,"wires":[["ee20c59b6e135fcc"]]},{"id":"ee20c59b6e135fcc","type":"ui-text","z":"e185156382741029","g":"f50e3ea43f4e79f3","group":"bf88c513dcf7e24c","order":8,"width":"1","height":"1","name":"","label":"Served from cache","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":350,"y":460,"wires":[]},{"id":"62d336cae4d4126b","type":"link call","z":"e185156382741029","g":"c4b1e262e5c5f7ae","name":"Getmeteogram","links":["d42ac7c1b5719dd1"],"linkType":"static","timeout":"30","x":180,"y":280,"wires":[["7fefefa4531004e3"]]},{"id":"7fefefa4531004e3","type":"ui-template","z":"e185156382741029","g":"c4b1e262e5c5f7ae","group":"4d960df950a4fce6","page":"","ui":"","name":"Meteogram","order":4,"width":"2","height":"1","head":"","format":"<template>\n    <p>{{msg.payload}}</p>\n    <div class=\"meteogram\">\n        <img :src=\"`/${msg.payload}`\"  alt=\"Check httpStatic in settings.js\" style =\"max-width:100%; height:auto; border: 1px solid silver;\">\n    </div>\n</template>\n","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":370,"y":280,"wires":[[]]},{"id":"44a02ea31662a7f1","type":"link call","z":"e185156382741029","g":"c4b1e262e5c5f7ae","name":"GetForecast","links":["b2ed74cc5a434824"],"linkType":"static","timeout":"30","x":170,"y":320,"wires":[["8b5a870af69e6eb8","cd7e51f49f3580b7"]]},{"id":"5782379537035808","type":"ui-slider","z":"e185156382741029","g":"e691f8bead778534","group":"bf88c513dcf7e24c","name":"","label":"Slider","tooltip":"","order":4,"width":"1","height":"1","passthru":false,"outs":"all","topic":"slider","topicType":"str","thumbLabel":"false","showTicks":"always","min":0,"max":"5","step":1,"className":"","iconPrepend":"","iconAppend":"","color":"","colorTrack":"","colorThumb":"","showTextField":false,"x":350,"y":180,"wires":[["3b0226dbc133341d"]]},{"id":"4f96c1deb4cb92f9","type":"ui-radio-group","z":"e185156382741029","g":"e691f8bead778534","group":"bf88c513dcf7e24c","name":"","label":"Radio Group ","order":2,"width":"1","height":"1","columns":1,"passthru":false,"options":[],"payload":"","topic":"radio","topicType":"str","className":"","x":370,"y":140,"wires":[["6739d3a99001bd4e"]]},{"id":"d27fa0f6a5665828","type":"ui-button-group","z":"e185156382741029","g":"e691f8bead778534","name":"Button Group","group":"bf88c513dcf7e24c","order":6,"width":"4","height":"1","label":"Choose a Location","className":"","rounded":true,"useThemeColors":true,"passthru":false,"options":[{"label":"","icon":"","value":"option_0","valueType":"str","color":"#009933"},{"label":"","icon":"","value":"option_1","valueType":"str","color":"#999999"}],"topic":"button","topicType":"str","x":370,"y":60,"wires":[["6739d3a99001bd4e"]]},{"id":"8fcca52857e4ad81","type":"link in","z":"e185156382741029","g":"e691f8bead778534","name":"locations","links":["2e3967a1027bc4d3"],"x":100,"y":100,"wires":[["6447d43ea61ac710"]],"l":true},{"id":"2e0d87020bd3853d","type":"function","z":"e185156382741029","g":"e691f8bead778534","name":"Interpret","func":"const places = flow.get(\"places\") ?? []\nmsg.payload = places[msg.payload]\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":180,"wires":[["927b86f9a7ec8511","2cb1bf239d2b9e02"]]},{"id":"6f38a339c19ab4fe","type":"ui-text","z":"e185156382741029","g":"e691f8bead778534","group":"bf88c513dcf7e24c","order":7,"width":"1","height":"1","name":"","label":"Selected","format":"{{msg.payload}}","layout":"row-left","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":780,"y":60,"wires":[]},{"id":"927b86f9a7ec8511","type":"change","z":"e185156382741029","g":"e691f8bead778534","name":"name","rules":[{"t":"move","p":"payload.name","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":60,"wires":[["6f38a339c19ab4fe"]]},{"id":"3b0226dbc133341d","type":"trigger","z":"e185156382741029","g":"e691f8bead778534","name":"slow","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"500","extend":true,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":470,"y":180,"wires":[["6739d3a99001bd4e"]]},{"id":"ddabd25ec5742fcc","type":"ui-template","z":"e185156382741029","g":"e691f8bead778534","group":"","page":"0fc69c901da5d235","ui":"","name":"Show widget borders","order":0,"width":0,"height":0,"head":"","format":".nrdb-ui-widget {\n    border: 1px solid yellowgreen;\n}\n.nrdb-ui-group {\n    border: 1px solid crimson;\n}","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"page:style","className":"","x":140,"y":60,"wires":[[]]},{"id":"6447d43ea61ac710","type":"function","z":"e185156382741029","g":"e691f8bead778534","name":"Setup locations","func":"const places = msg.payload\nflow.set (\"places\", places)\n\nlet buttonoptions = []\nplaces.forEach(function (item, index) { \n    buttonoptions.push({ \"dropdown\": \"Location\", \"label\": item.name, \"value\": index, \"icon\": item.icon }) \n});\nlet buttonmsg = { \"ui_update\": { \"options\": buttonoptions, \"max\": places.length - 1 } } // max is for length of slider\n\nreturn buttonmsg","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":120,"y":140,"wires":[["308b66ba3969e981"]]},{"id":"d7932b0f1773fdfa","type":"ui-dropdown","z":"e185156382741029","g":"e691f8bead778534","group":"bf88c513dcf7e24c","name":"","label":"Dropdown","tooltip":"","order":3,"width":"1","height":"1","passthru":false,"multiple":false,"chips":false,"clearable":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"drop","topicType":"str","className":"","typeIsComboBox":true,"msgTrigger":"onChange","x":370,"y":100,"wires":[["6739d3a99001bd4e"]]},{"id":"4d960df950a4fce6","type":"ui-group","name":"Weather","page":"0fc69c901da5d235","width":"5","height":1,"order":2,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"bf88c513dcf7e24c","type":"ui-group","name":"Selection","page":"0fc69c901da5d235","width":"7","height":1,"order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"0fc69c901da5d235","type":"ui-page","name":"Weather - Tabs","ui":"d45641ed6d39fea1","path":"/tabs","icon":"home","layout":"tabs","theme":"0d92c765bfad87e6","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":4,"className":"","visible":"true","disabled":"false"},{"id":"d45641ed6d39fea1","type":"ui-base","name":"This is my ui-base","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":false,"notificationDisplayTime":5,"showDisconnectNotification":false},{"id":"0d92c765bfad87e6","type":"ui-theme","name":"Basic Blue Theme","colors":{"surface":"#4d58ff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"2px","density":"default"}}]
Thanks so much for doing this - will give me something to sink my teeth into and modify for my local weather needs as well
Very much appreciated
Craig
Nobody interested to enhance this with CSS?
:thinking:
If only I used dashboard 2, I could try and turn it into a platform arrivals board again :wink:
That was three years ago! All them trains have long departed :upside_down_face:
I do still use that departures dashboard but annoyingly it's quicker to search for Waterloo Departures in a browser than to remember the right IP address /ui
Umm yeah. I wonder what proportion of people use the various dashboard solutions.
I'm sure you will be surprised to note that I use UIBUILDER. :rofl:
