Http in message local nodered
Hi all, I want to receive a SigFox http message on my local node-red running on the server. I use the http in node to receive this message with the url /SigFox, in the SigFox backend i use https://myNodeRed.com/SigFox to send the message. This message is never seen by nodered. Doing the same using an IBM node-red the message is received. So my question is how do i receive a htttp in call back from SigFox on my local nodered?
Don't you need to add the port number in the url?
https://myNodeRed.com:1880/SigFox
That[quote="Paul-Reed, post:2, topic:21356"]
[/quote]
That assumes the 'local node-red' is actually exposed to the internet at all.
@Meng can you describe a bit more about how/where your local node-red is running?
I suspect you mean you have it on your home network, which means it is not publicly accessible - so the SigFox service cannot reach it. It would work on the IBM Cloud instance because that has a publicly accessible url.
You are right the node-red is only accessible via the local network. How should i change this? MQTT on the other hand is working.
This may help you - https://github.com/node-red/cookbook.nodered.org/wiki/How-to-safely-expose-Node-RED-to-the-Internet
