"Http In"-Subflow OR "Url must be unique?"
It seems to me, that the url parameter for HttpIn Nodes must be unique, for only the first instance created will be triggered by a request.
So if i have multiple HttpIn Nodes using the same route, only one gets triggered.
Furthermore, i tried to create a HttpIn Node with a parameterized url, which i used in a subflow, thinking that i could filter on the parameter... Again only one instance of my subflow was triggered.
Is this correct and if it is, is there any known workaround?
Kind regards,
Tobi
Yes, that behaviour is indeed correct. If you’re hoping to have the handling changed depending on parameters, your best bet is to add a switch node behind the http-in, and have all different actions behind the different outputs on the switch, then wire it back to an http-response node.
And you can use named parameters ( :foo ) - in the url - see the node info.
I believe that has already been tried, but I may have misinterpreted :slight_smile:
The issue here is that when in a subflow, if the instance doesn’t have a way of making it a unique url only one instance will be triggered. So either make sure that the URL is unique, say you use a subflow instance id or something in the address, or handle the different actions in subflows but the http-in on top of it
Thanks for your input.
That sounds similar to what i was trying to achieve. But how am i supposed to get the subflow instance id into the url?
Using parameterized urls (:something) does not work with multiple subflow instance, as stated above. Your interpretation was correct.
Currently i have a "Global Stuff"-Tab where i put the Endpoint. Then i use Link-Nodes to relay the message to of all my subflow instances across different tabs.
Inside the instances, i then handle the message differently, depending on the passed url parameter. At most one of these instances does something by design.
I was hoping to get the Endpoint INSIDE the subflow, so i can make the subflows self-sufficient and eliminate the link-nodes.
