HTTP Request Node and payload propagation
I've to do a sequence of http request (REST API) and i've to propagate some initial information, so i've to put on the response after each HTTP Request Block the input payload. How i can do this ?
I've see that with GET I can do it, but if i've to do a POST the option to mantain in the response the input payload is not showed.
thank's advance
best regard's
Gian-Luca
If you wish to retain the output payload between requests, you will need to move the payload to a different property before doing the next call. You can do that with a change node.
Just note that if you wish to retain any of the ExpressJS metadata (such as headers for example), you will need to make a copy of those to a different property since they will be overwritten of course by the next call.
your solution was the trick, thank's
Gian-Luca
