I've set up node-red to behind a nginx-proxy and have a hard time to reach the httpStatic content. If i connect to localhost:1880/test.png (test.png is within httpStatic folder) it works fine. But when i try to use the same file in template node as such:
<div> <button onclick="window.location.href = "google.com"><img src="/test.png"></button></div>
I only get 404 not in console.
This is snippet rom my node-red settings.js:
httpAdminRoot: '/admin',
httpNodeRoot: '/node-red',
//httpRoot: '/node-red',
httpStatic: '/home/antsve/node-red',
and this is the nginx.settings for my host:
location /node-red {
              proxy_pass http://127.0.0.1:1881/node-red;
              proxy_http_version 1.1;
              proxy_set_header Upgrade $http_upgrade;
              proxy_set_header Connection "upgrade";
              proxy_set_header X-Forwarded-Host $host:server_port;
              proxy_set_header X-Forwarded-Server $host;
              proxy_set_header X-Forwarded-for $proxy_add_x_forwarded_for;
location /admin {
              proxy_pass http://127.0.0.1:1881/admin;
location /static {
              proxy_pass http://127.0.0.1:1881;
              proxy_set_header X-Forvarded-Server $host;
              proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
anyone have any suggestions to what im doing wrong?
