If not equal to "string" and equal to number - function node
Hello NodeRED Community,
i have a quite bad issue which i can not solve out of the box:
Currently i have a function node which has this function that is not working:
var valueSensorMode = msg.payload.valueSensorMode
var valueHardUpperLimit = msg.payload.valueHardUpperLimit
var valueLimitValue = msg.payload.valueLimitValue
var valueHardLowerLimit = msg.payload.valueHardLowerLimit
var currentValue = msg.payload.valueInteger
if(valueSensorMode!== "standby" && currentValue > valueHardUpperLimit){
    msg.payload.valueResult = "out of upper limit"
    return msg
if(valueSensorMode!== "standby" && currentValue < valueHardLowerLimit){
    msg.payload.valueResult= "out of lower limit"
    return msg
if(valueSensorMode!== "standby" && currentValue > valueHardLowerLimit && currentValue < valueHardUpperLimit){
    msg.payload.valueResult = "value ok"
    return msg
if(valueSensorMode=== "standby"){
    msg.payload.valueResult == "evaluation not available"
    return msg
I have the following message / msg.payload as an input format:
   "sensorTime":1673284939618,
   "valueInteger":114.9,
   "valueMachineMode":"standby",
   "valueHardUpperLimit":2,
   "valueLimitValue":0,
   "valueHardLowerLimit":-2
And I am expecting an output message / msg.payload (according to the dedicated intput) that has an additional field which is the "valueResult":
   "valueHardLowerLimit":-2,
   "valueResult": "evaluation not available"
Can anybody help?
You have the standby result shown originating from msg.payload.valueSensorMode
and yet in in your input, the standby result is at msg.payload.valueMachineMode
Shouldn't you be using - var valueSensorMode = msg.payload.valueMachineMode
Hi there. I’m not at a computer at the moment, so I can’t run your code, but the first thing that stands out to me is that the line where you set the valueResult to “evaluation not available”, you have == and not =
(So you are performing a test, and not an assignment)
Thats it... I didn't see that..
Thank you very much for your input!
