I started to use Node-RED a few weeks ago. Actually, this was just to test and see if I can use it for a home security system. As usual, I created a git repository from the node-red folder and made commits.
Now that my POC is completed, I'd like to go on with the projects feature and retrieve my git history.
But I have problem reimporting the existing as I was using an system-generated key. What should I do? Change to a personal key, commit, push and then clone to the new node-red instance with the projects feature enabled?
Thanks!
