Where is the import and export menu in release 1.0?
Is there a way to bring out the menu besides using shortcut key?
Its on all my 1.0.0 installs
What platform are you on - was it clean install or an upgrade?
It is clean installation.
I am using docker image and run docker on windows10 docker desktop.
Dockerfile looks like below:
FROM centos
# install base lib
RUN yum install -y curl
RUN yum install -y gcc-c++ make
RUN yum install -y dos2unix
# install node.js
RUN curl -sL https://rpm.nodesource.com/setup_10.x | bash - && yum install -y nodejs
# install node-red
RUN npm install -g --unsafe-perm node-red@1.0.0
Then, the editor looks like:
I can see you must have a custom theme set under editorTheme. Can you share what you have customised?
Hi @knolleary you are right. We changed several icons only
// Customising the editor
editorTheme: {
page: {
title: "MY Flow Editor",
favicon: "/node-red/data/image/myicon.ico",
css: "/absolute/path/to/custom/css/file"
header: {
title: "MY EDITOR",
image: "/node-red/data/image/favicon.ico", // or null to remove image
url: "" // optional url to make the header text/image a link to this url
deployButton: {
// type:"simple",
type:"default",
label:"Save",
icon: "/absolute/path/to/deploy/button/image" // or null to remove image
menu: { // Hide unwanted menu items by id. see editor/js/main.js:loadEditor for complete list
"menu-item-import-library": false,
"menu-item-export-library": false,
"menu-item-keyboard-shortcuts": false,
"menu-item-help": {
label: "Alternative Help Link Text",
url: "http://example.com"
// userMenu: false, // Hide the user-menu even if adminAuth is enabled
login: {
// image: "/absolute/path/to/login/page/big/image" // a 256x256 image
image: "/node-red/data/image/MY_logo_DDM_256.png"
@knolleary
With your hint, we changed the menu-item-import-library and menu-item-export-library to true and now it looks good. Thank you very much
