Good afternoon,
I'm having problems configuring the Influx Configuration Node (i.e., the Influx Server selected when setting up an InfluxDB In or InfluxDB Out Node). I'm using InfluxDB v1.8
- Occasionally the protocol defaults to
https://
even when "secure connection" checkbox is unchecked. The only way I've found of reverting to http: is to select "secure", deploy, then deselect it and deploy again. The JSON configuration node below hashttp://
but also has a blank SSL/TLS node. It this correct/expected?
"id": "b644ba197cda86be",
"type": "influxdb batch",
"z": "4c457c4eb7ed6a80",
"influxdb": "6ca8bde.9eb2f55",
"precision": "",
"retentionPolicy": "",
"name": "Influx Out Batch (v1.x)",
"database": "database",
"precisionV18FluxV20": "ms",
"retentionPolicyV18Flux": "",
"org": "organisation",
"bucket": "bucket",
"x": 1100,
"y": 480,
"id": "6ca8bde.9eb2f55",
"type": "influxdb",
"hostname": "172.20.0.2",
"port": "8086",
"protocol": "http",
"database": "mydb",
"name": "InfluxDB B1.x (172.x.x.x)",
"usetls": false,
"tls": "f7f39f4e.896ae",
"influxdbVersion": "1.x",
"url": "",
"timeout": "",
"rejectUnauthorized": false
"id": "f7f39f4e.896ae",
"type": "tls-config",
"name": "local-tls",
"cert": "",
"key": "",
"ca": "",
"certname": "",
"keyname": "",
"caname": "",
"verifyservercert": false
I have found that I can export the node, edit it to http://
if necessary and re-import it if https://
persists.
- The second problem occurs, again when configuring the Configuration Node. The port is consistently 8086 (and this is confirmed in Portainer), below:
[influxdb] healthy iotstack [influxdb:1.8] 2024-02-07 07:36:43 172.20.0.2 [8086:8086] administrators
As you can see it was installed via IOTstack using its defaults.
The issue concerns the host and port settings. I expected to be able to use any of:
[mylocalip_address] <-- (e.g., 192.168.1.100)
[hostname.local] <-- (e.g., myraspberrypi.local)
[localhost]
... but none of these will connect to InfluxDB. The only host that 'works' is:
[172.20.0.2]
... which is the IP address reported in Portainer, above, and which is, I assume(?), the IP address INSIDE the container that is eventually mapped to the local network IP address. That would be OK were it not for fact that a restart of the container results in a change of this IP address. I need something that endures.
NOTE: when accessing influxdb from Grafana, the followin g connection is successful
http://192.168.1.100:8086
I'm new to much of this and I'm now lost as to why, where to look and what to do.
Any and all help much appreciated,
Ric
