Insert flow variables in message payloads
Hi everyone,
here comes another easy challenge for the Node-Red pros among you :smile: Following situation: Based on a certain trigger, I would like to send a message payload to an Alexa node that contains data from some flow variables I defined.
Here is my example for the msg.payload I would like to create from a change node using the JSONata editor:
"Outside temperature is about "& flow.get("OutsideTemp") &" degrees at "& flow.get("Humidity") &" % humidity"
Unfortunately, the variables get simply ignored when creating the actual object. Now tell me what´s the trick to integrate flow variables into messages :mage:
I will do this myself in a function node.
In a function node you concatenate strings with a + instead &.
msg.payload= "Outside temperature is about "+ flow.get("OutsideTemp") +" degrees at "+ flow.get("Humidity") +" % humidity"
return msg
In JSONata expression it would be $flowContext("OutsideTemp") not flow.get
Beautiful :smiley: Thanks both @edje11 & @E1cid for the quick response!
Here's a picture of my flow to get a report on my Raspberry Pi.
And here's what 'Format response' looks like using Javascript...
