I would appreciate help with inserting a data record into a MSSQL database table. I am using the MSSQL-PLUS node. My flow obtains SQL column name and data (could be string or floating number) from an Excel worksheet. This part works fine. Also the MSSQL-PLUS node works fine to connect to the database. I have been struggling with the syntax of the INSERT statement, to get the payload into just the right form for MSSQL to accept it. Here is the flow:
The string values should have quotes and the numbers no quotes. The field names should not have quotes. Can the MSSQL node handle input in the present form or does the input stream need further conditioning, and what should the INSERT statement look like?
Is it the case that the field names must be "hard-wired" into the INSERT statement, as is done here? If so, there is no need for me to generate that part of the input stream. The input stream would only need to have data.
