Intellisense not working on SMLight Zigbee stick
I'm using NR on a Zigbee stick (who'd have thought!), the SMLight SMHUB Nano MG24. It wants to control installed software itself, and it looks like they've got a problem I should report. The intellisense syntax checking (edited as intellisense works) doesn't seem to be properly hooked up for msg, node, flow etc.
If I hover over the error it says "Cannot find name 'msg'", although if I deploy, the code runs fine. I can also insert // @ts-nocheck to sidestep the issue, but it would be nice to point them in the right direction regarding a fix.
