Is anyone else seeing these errors in the Editor (in dev tools console)?
I am getting them when closing any node config panel.
Trying to work out if it is something I've done as I'm only seeing it on my Windows dev instance.
Running Node-RED v3.1.5 in Edge browser.
can you click the highlighted links and and show a small snippet of code so we we can get perspective?
Doble checking: config nodes and regular nodes or just config nodes?
Config nodes as well.
The emit error:
Comes from RED.events.
The 2nd link is from RED.tray, the showTray function:
The 3rd link is also from RED.tray, the showTray function:
4th link:
The 2nd error is exactly the same but points to line 1049 of the emit function instead of 1048. Actually, that line seems superfluous anyway since I think that the err object could be passed as a 2nd argument to the console.warn?
I dont see this (but i am in dev v4 branch exclusively ATM)
Hoping someone else will pop by and let us know.
Thanks for the info Julian.
I am not seeing it. NR 3.1.5, Also Edge browser.
Ah!! Took me a while to work out how to go down the rabbit hole of nested indirect function calls! Got there in the end though.
It is in my own code:
        // https://discourse.nodered.org/t/special-indication-on-nodes-with-description/78646/76
        // RED.view.node_width and RED.view.node_height
        RED.events.on( 'editor:close', () => {
            let x = 0
            let y = 0
            $(`#${n.id}`).find('.red-ui-info-available-indicator').remove()
            RED.nodes.eachNode( n => {
                y++
                if ( n.info ) {
                    x++
                    // $(`#${n.id}`).append('<g class="red-ui-flow-node-available-indicator" transform="translate(5,5)"><circle cx="5" cy="5" r="5"></circle></g>')
                    // // NB: You have to re-render the container (ref: https://stackoverflow.com/a/36305466/1309986):
                    // $(`#${n.id}`).html($(`#${n.id}`).html())
            console.log(x, y)
I suspected it must be. As you will all no doubt see faster than I did, there is a rather obvious error in that code. :slight_smile: Over optimisation at its finest :person_facepalming:
Thanks for all who looked though.
