Is it possible to delete (disable permanently) some nodes from nodered module
Hi!
Is it possible to delete or disable some nodes form nodered module/package?
Check out your settings.js file, the block list is found in there.
Thanks for your answer TotallyInformation!
can you please specify where exactly?
I checked there is a denyList but I think it applies to a whole package.
Is that where you mean? if yes is there a pattern that should be applied?
Or do you mean somewhere else?
See here: How to customize the node red editor - #18 by Steve-Mcl
