Im a complete newbie to node-red, so I just installed it on my pc. I want to change the logos from node-red to my own logo but when I try this with the command editorTheme I get the notification(see title).
Hi @Beasty
editorTheme isn't a command you run - its one of the settings available in your settings.js file.
You should edit settings.js in a text editor, find the editorTheme section in there and add the settings you want to it.
If you aren't sure where your Node-RED settings file is, Node-RED logs the full path to the settings file it is using when it starts up.
