Is there a way to add a library store without users having to change settings.js? If not, should there be?
UIBUILDER now has rather a lot of examples and I think it can be quite hard to work through them, especially if you have a lot of other nodes installed that also contribute examples.
I know that you can add a node-red-library-source plugin. However, this requires users to make manual changes to settings.js which isn't very user-friendly.
So is there a legitimate way to avoid forcing users to make that change?
If not, should this be a requested improvement to Node-RED? Thoughts?
Thanks.
