Hi, I'm new to nodered and am trying to pull tags from a 1769 CompactLogix L33ER with the node-red-contrib-cip-st-ethernet-ip node, then pass them with MQTT Sparkplug.
I only seem to be able to pull the controller tags and not any tags that are defined in the main program.
Is there something I need to add in the node tag configuration in order to get those tags or am I only able to access the controller tags?
I am entering the name of the tag exactly as it appears in the exported csv tag list and have checked the data type.
When I deploy the node it says its online and doesn't have any errors; but it only returns a null value.
I double checked in studio 5000 and there is a value for the tag but I just am not getting it.
Thanks.
