Issues with creating different projects
I'm currently trying to understand how to create separate node-red projects, but as of now I'm stuck in place.
I have read the https://nodered.org/docs/user-guide/projects/ guide and followed the instructions up until the point where I have changed the settings.js file to enable for projects:
(value was initially set to false)
But now when trying to restart node-red it automatically goes back to my previous project where I currently have three flows active instead of being greeted by the welcome screen as shown in the guide:
shows instead of:
Any idea how I can start with a fresh flow, in another json file so that I can separate my different projects instead of having them all in separate flows? Or is this just available for Mac-users?
Best regards,
Alexander
Hi @Unikumet
Node-RED only shows that dialog the very first time you enable the projects feature when you have not yet created a project. After that, once you have enabled projects, node-red will load the 'active' project when it starts up.
To create a new project, select "Projects->New" from the dropdown menu in the right-hand corner of the editor.
https://nodered.org/docs/user-guide/projects/#creating-new-projects
