JSONATA for chart
I’m working with charts. The acquired data return three measures for each reading.
This is a sample of some of these.
    "m_devID": 1,
    "m_time": "2022-04-04T13:48:11.000Z",
    "temperature": "17.65",
    "cond": "2900",
    "hum": "4.36"
    "m_devID": 1,
    "m_time": "2022-04-04T14:08:11.000Z",
    "temperature": "17.59",
    "cond": "2900",
    "hum": "4.36"
    "m_devID": 1,
    "m_time": "2022-04-04T14:28:11.000Z",
    "temperature": "17.54",
    "cond": "2900",
    "hum": "4.36"
I transform the data in order to be used with chart, to di so I’ve implemented one for cycle and I build what I need.
These data are the transformed ones.
    "series": [
      "Temp °c",
      "Hum. %",
      "Cond mS/cm"
    "data": [
          "x": 1649080091000,
          "y": 17.65
          "x": 1649081291000,
          "y": 17.59
          "x": 1649082491000,
          "y": 17.54
          "x": 1649080091000,
          "y": 4.36
          "x": 1649081291000,
          "y": 4.36
          "x": 1649082491000,
          "y": 4.36
          "x": 1649080091000,
          "y": 2.9
          "x": 1649081291000,
          "y": 2.9
          "x": 1649082491000,
          "y": 2.9
    "labels": [
      "ltemp",
      "lhum",
      "lcond"
I’m convinced that is possible to do the same whit a simpler JSONATA operation, but I wasn’t able to find one. I’m wrong, does exist a simple JSONATA transform?
F.
Is there a particular reason for wanting to use jsonata?
Jsonata often looks as though it's more efficient because it uses less code, but as mentioned a number of times in the forum, it can take considerably more time to execute the code, than plain old JavaScript.
Just something to consider.
No, I solved the problem in the traditional way, but I've spent a lot of time trying (without a solution) with jsonata, and now I'm curious. :roll_eyes:
When I stopped to look for solutions I found, at least one.
Here it is:
       "labels":["Humidity", "Conductivity", "Temperature"],
       "series":["%", "mS/cm", "°C" ],
       "data": [
               Signature: $map(array, function)
               function(value [, index [, array]])
               $v is the value of m_time, $i is the array index, $a is the array (not needed here)
               $map(
                   payload.$toMillis(m_time),
                   function($v, $i, $a) {
                           'x': $v,
                           'y':payload[$i].$number(hum)
               $map(
                   function($v, $i) {
                           'x': $v,
                           'y':payload[$i].$number(cond) /1000
               $map(
                   function($v, $i) {
                           'x': $v,
                           'y':payload[$i].$number(temperature)
It needs three runs over payload so, as suggested by @Paul-Reed, I think is not so efficient. Maybe I make some performance tests.
Applied to this data
  "payload": [
      "m_devID": 1,
      "cond": "2900",
      "hum": "4.36"
      "m_devID": 1,
      "cond": "2900",
      "hum": "4.36"
      "m_devID": 1,
      "cond": "2900",
      "hum": "4.36"
Look here:
https://try.jsonata.org/J26OuQ1JW
Which could be reduced to
       "data": [
           $map(["hum","cond","temperature"], function($v){
           [$$.payload.{
                'x': $toMillis($.m_time),
                'y': $number($lookup($,$v))
This node is ideal for checking performance times - GitHub - bartbutenaers/node-red-contrib-msg-profiler: A Node-RED node to execute time profiling (and tracing) of a message through a flow
Thanks. Very concise query. If I understand it cycles three times, one for every parameter inside the array ["hum","cond","temperature"].
I've to better understand JSONATA and the use of parameters, and the documentation isn't very easy. Too much $ :slightly_smiling_face:.
@Paul-Reed very useful node.
