I have a Node-Red installed and configured on mine main PC that i am using most of the time for testing/developing flows...
I have set a lot of custom keyboard shortcuts that i am used to using while developing.
How could i transfer all of the shortcuts to another Node-Red instance without having to manually input every shortcut?
Is there a config file for them?
Have a look under ~/.node-red/.config.users.json - that contains all of your editor options, including keyboard shortcuts as a big JSON document. The top-level key of the document is your username if have adminAuth enabled, otherwise it uses "_" as the key for the default user.
You should be able to copy the whole file over.
