Launching node-red(error of infinite loop)
when I start node-red, I see this error:
I would guess that you have some code that has an infinite loop somewhere.
However, you need to share details about your environment (node.js, node-red,etc version numbers, OS, platform).
Also, sharing your flow might be helpful.
yes i have an infinite loop somewhere, I know where is this error but how can I delete the node through cli or file ?
Ah, sorry, of course.
If you are using the latest version of Node-RED, you should be able to restart it using the safe option so that the flows don't automatically start.
  • Add --safe mode flag to allow starting without flows running. This can be used if a flow is causing Node-RED to crash - starting in safe mode will allow the editor to be used to modify the flow and then deploy the change to take it out of safe mode.
I have version 0.19.6, where i put --safe mode
Unfortunately it only came in v0.20
As @ukmoose says, that option was only added in 0.20.
You can either hand-edit your flow file, identify the offending node and delete it, or move the flow file to a new location so Node-RED starts with a blank set of flows. You can then import your old flows bit by bit.
If you aren't sure where your flow file is, Node-RED logs the full path to the file its using when it starts up.
thank you, it works now when i upgrade NR to v0.20 and use the safe mode
