Can you use logging functions such as console.log() and node.log() in the Angular in the ui template node? No output appears, but they work fine in the function node.
The code in a ui-template execute client side, console.log should log in the developers section of the browser.
@E1cid thank you! I see all the output. You can see I am a newbie. Most appreciated!
