Lost Basic-Pallete Nodes
Greetings
I have 'lost' a number of basic nodes from the initial NR install set, all related to http-request etc. I do have backups and can reinstall, but that won't help me to learn either the source of the problem or methodology to cure.
If I go to manage the palette, the basic node-red node (0.20.2) shows a red error triangle and the term "[object Object]". Looking at the list of individual nodes within the group shows a number that have 'marching ants' around their symbol; all of these are missing from the general node-red palette. Most are related to HTTP Requests but also MQTT Broker.
Any hints would be gratefully received.
Tom
Did you follow the upgrade procedure as described in:
https://nodered.org/docs/getting-started/upgrading
Hi Colin
Yes. Initially I had a wider issue with NR. Running the re-istallation process (on a Rpi) got me back up and running, albeit with the missing nodes issue.
Did you use the bash <(curl script?
Show us the output you get from
node-red-stop
node-red
Copy/paste it rather than screenshot if possible please
Thanks Colin... Start and Stop outputs follow....
pi@Burrow : ~/.node-red $ node-red-stop
Stop Node-RED
Use node-red-start to start Node-RED again
17 Mar 18:57:40 - [info]
Welcome to Node-RED
17 Mar 18:57:40 - [info] Node-RED version: v0.20.2
17 Mar 18:57:40 - [info] Node.js version: v8.11.1
17 Mar 18:57:40 - [info] Linux 4.14.98-v7+ arm LE
17 Mar 18:57:43 - [info] Loading palette nodes
17 Mar 18:57:53 - [info] Dashboard version 2.9.8 started at /ui
17 Mar 18:57:53 - [warn] ------------------------------------------------------
17 Mar 18:57:53 - [warn] [node-red/httpin] SyntaxError: Invalid or unexpected token
17 Mar 18:57:53 - [warn] [node-red-node-feedparser/feedparse] SyntaxError: Invalid or unexpected token
17 Mar 18:57:53 - [warn] [node-red-node-twitter/twitter] SyntaxError: Invalid or unexpected token
17 Mar 18:57:53 - [warn] [node-red-contrib-sqldbs/sqldbs] SyntaxError: Invalid or unexpected token
17 Mar 18:57:53 - [warn] [node-red-node-twilio/twilio] SyntaxError: Invalid or unexpected token
17 Mar 18:57:53 - [warn] [node-red-contrib-http-request/www-request] SyntaxError: Invalid or unexpected token
17 Mar 18:57:53 - [info] Settings file : /home/pi/.node-red/settings.js
17 Mar 18:57:53 - [info] HTTP Static : /home/pi/.node-red/public
17 Mar 18:57:53 - [info] Context store : 'default' [module=memory]
17 Mar 18:57:53 - [info] User directory : /home/pi/.node-red
17 Mar 18:57:53 - [warn] Projects disabled : editorTheme.projects.enabled=false
17 Mar 18:57:53 - [info] Flows file : /home/pi/.node-red/flows.json
17 Mar 18:57:54 - [info] Server now running at http://127.0.0.1:1880/
17 Mar 18:57:54 - [warn]
your credentials.
17 Mar 18:57:54 - [info] Starting flows
17 Mar 18:57:56 - [info] Started flows
17 Mar 18:57:56 - [info] [mqtt-broker:74c316c3.026408] Connected to broker: mqtt://192.168.1.11:1883
17 Mar 18:57:56 - [info] [mqtt-broker:dada5f69.223af] Connected to broker: mqtt://192.168.1.11:1883
17 Mar 18:57:56 - [info] [mqtt-broker:50f5ed4f.6d0c74] Connected to broker: mqtt://192.168.1.11:1883
17 Mar 18:57:56 - [info] [mqtt-broker:e5246d28.e8b65] Connected to broker: mqtt://192.168.1.11:1883
17 Mar 18:57:56 - [info] [lifx:Tiffany LIFX ON] New bulb found: Tiffany : d073d524dc9a
17 Mar 18:57:56 - [info] [lifx:Tiffany LIFX OFF] New bulb found: Tiffany : d073d524dc9a
^C17 Mar 18:58:42 - [info] Stopping flows
At the command line can you run
npm -v
And report which version it says ?
dceejay, it's 6.4.1
