Hi
Anyone experiencing this issue?
MacOs 18
Node-Red 4.0.4 (but older releases showed the issue)
When i search for a node in the right tab of node-red, the node-list becomes more emtpy after each search.
Also, cmd+click on the flow, shows the quick node search panel, that disappears once cmd key is released.
Thanks.
Confirmed, seems an issue (again) with Safari...
does it happen in other browsers?
I'm still on Ventura v13.6.7 and I'm not seeing the issue NR v4.0.2 and Safari v17.5
What version of Safari are you running
No, seems Safari only
v18.0.1
Hi
Chrome ist fine.
Version of Safari? 18.0.1 and 18.1
Same problem for me, MacOS 15.1.1, Safari 18.1.1, Nodered 4.0.3 under Home Assistant 2024.11
All works fine under MacOS Firefox
I thing the problem occurred since MacOS 15
