Messed up menu and dialogs tags
Hi guys, don’t ask how but after some changes in security settings, now my node red menu and all the dialogs are messed up like this:
Node Red in Docker container behind Nginx reverse proxy with Letsencrypt ssl and Node Red basic auth
Any hints?
Hi, could you check if the file is formatted correctly. Do you see any error in the browser console? What did you change in that file?
In your browser's Dev tools, keep an eye on the network tab. Looks like you're not getting the i18n data. Perhaps your nginx config or proxy/firewall/security blocked that?
