is there a way to configure the autoscale so it has a floor resolution? i'm doing temperature stuff and at .1 resolution it looks like /\/////// when sitting idle. i would like it if it could 'zoom out' but still use autoscale for when it climbs. ie: now my entire graph top to bottom when idle is .4 degrees. i'd like it to be a minimum of 2 degrees, then scale as needed when it diverges.
No sure I understood the problem correctly but maybe this example helps you out
[{"id":"b6c503e0554e4265","type":"ui_artlessgauge","z":"09deee63c1b960f7","group":"08ac9b242ae51e8c","order":5,"width":0,"height":0,"name":"","icon":"fa-thermometer","label":"Gauge","unit":"watt","layout":"linear","decimals":"2","differential":true,"minmax":true,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#ff9900","t":"min","dot":0},{"val":10,"col":"#ff9900","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"0","x":660,"y":920,"wires":[]},{"id":"cc8e556.23e4ea8","type":"function","z":"09deee63c1b960f7","name":"","func":"let val=msg.payload;\nlet Wsectors = [{t:\"min\",val:-3000,col:\"#00ff00\",dot:0},{t:\"sec\",val:0,col:\"#ff0000\",dot:3},{t:\"max\",val:5000,col:\"#0000ff\",dot:0}];\nlet kWsectors = [{t:\"min\",val:-3,col:\"#00ff00\",dot:0},{t:\"sec\",val:0,col:\"#ff0000\",dot:3},{t:\"max\",val:5,col:\"#0000ff\",dot:0}];\nvar newSectors,unit;\n\nif (val >= 1000 || val <= -1000){\n msg.payload=val/1000;\n newSectors=kWsectors;\n unit=\"kiloWatt\";\n} else {\n newSectors=Wsectors;\n unit=\"Watt\";\n}\nmsg.control = {unit:unit,label:\"Grid Activity\",icon:\"fa-plug\",sectors:newSectors};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":960,"wires":[["c5a5348b.574418","6a81ae9c.deb0d","b6c503e0554e4265"]]},{"id":"c5a5348b.574418","type":"debug","z":"09deee63c1b960f7","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":630,"y":960,"wires":[]},{"id":"6a81ae9c.deb0d","type":"ui_artlessgauge","z":"09deee63c1b960f7","group":"08ac9b242ae51e8c","order":6,"width":4,"height":4,"name":"","icon":"","label":"Gauge","unit":"","layout":"radial","decimals":"2","differential":true,"minmax":true,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":false,"animate":true,"sectors":[{"val":0,"col":"#ff9900","t":"min","dot":0},{"val":10,"col":"#ff9900","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"0","x":660,"y":1000,"wires":[]},{"id":"d365f512a279dfe1","type":"ui_button","z":"09deee63c1b960f7","name":"","group":"08ac9b242ae51e8c","order":7,"width":2,"height":1,"passthru":false,"label":"500","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"500","payloadType":"num","topic":"topic","topicType":"msg","x":270,"y":900,"wires":[["cc8e556.23e4ea8"]]},{"id":"e865c9069b603de0","type":"ui_button","z":"09deee63c1b960f7","name":"","group":"08ac9b242ae51e8c","order":8,"width":2,"height":1,"passthru":false,"label":"2500","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"2500","payloadType":"num","topic":"topic","topicType":"msg","x":270,"y":940,"wires":[["cc8e556.23e4ea8"]]},{"id":"7790f9cef3019cf2","type":"ui_button","z":"09deee63c1b960f7","name":"","group":"08ac9b242ae51e8c","order":9,"width":2,"height":1,"passthru":false,"label":"-2500","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"-2500","payloadType":"num","topic":"topic","topicType":"msg","x":270,"y":980,"wires":[["cc8e556.23e4ea8"]]},{"id":"df94b86bf73fc57a","type":"ui_button","z":"09deee63c1b960f7","name":"","group":"08ac9b242ae51e8c","order":10,"width":2,"height":1,"passthru":false,"label":"-500","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"-500","payloadType":"num","topic":"topic","topicType":"msg","x":270,"y":1020,"wires":[["cc8e556.23e4ea8"]]},{"id":"08ac9b242ae51e8c","type":"ui_group","name":"Default","tab":"2acb95821445c8af","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"2acb95821445c8af","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
thanks for responding but this is for the chart, not the gauges.
when i have 5 inputs for temperature and they are very close the autoscale range makes it look very jumpy, because the entire y range for the chart is .4C. i'd like it so that it autoscales as necessasary when they ranges diverge, but i want to have a minimum value for the range of the y axis. ie: y axis will be at no less than 2 degrees range when inputs are <= 2, but when the delta between temps gets to 20 degrees, it will still scale correctly.
does that make more sense? help appreciated, i assume there some function that calculates the autoscale range, and it could just be told if range < 2, then range=2, but i'm not sure if it's that simple or where to find it
thank you
