Module Installation
Dear All
Hello. I am working with a hardware which only supports a basic version of NODE RED (v1.1.2). I have in the past installed modules via memory card and flash drive onto my device. However now I want to make use of the following Sparkplug module
I am unable to install this from offline sources. I also tried to check npm website for compatible versions but they do not work. Could you please suggest me any other sources where I could find the installation files for the above mentioned modules? Thank you.
Go to the flows tab at the top of the forum
enter in the node name, follow the GitHub link and then press the green Code button and you can download a zipped copy of the node.
