Hi.
Trying to extract data from a mongoDB Database. Have succeeded to extrakt all the data from a database. But it is a lot of data. Can I filter somehow. From the attached picture I want only Objektid that contains "name" : "system.operator.login.ok",
Have used mongodb2 and mongodb3
/Regards Niclas
I have not used MongoDB but I would have expected that you could request only those records when querying the database.
Hi Nicas,
You can use Mongodb's aggregation to filter out the matching records. In a preceding Function node :
msg.collection = "events" msg.operation = "aggregate" msg.payload = [ { "$match": { "name": "system.operator.login.ok" } }, //{ "$sort": { dt: -1}}, //{"$limit": 2}, //{"$skip": 0} ]; return msg;
The above is untested since we dont have you're db but i hope it gives you the result you want ps. im using node-red-node-mongodb
