MSSQL from RPi to Windows
Hello everyone. I am having trouble with sending queries from node-red-contrib-mssql-plus coming from my Pi to an MSSQL server in windows pc. This is the error:
"Login failed. The login is from an untrusted domain and cannot be used with Windows authentication."
But the first question is, is it possible? Second, if yes, anyone knows how to use this with Windows Authentication?
Thank you in advance.
Is this MS SQL Lite by any chance? eg. on a Windows desktop rather than a server? On a server, it would be unusual to use Windows authentication to connect to MS SQL.
Normally, you would need to use Kerberos. So a domain login would get a Kerberos token which is then passed onto the server.
Unfortunately, I have no understanding of the mssql-plus node so can't comment on what, if any, authentication and authorisation it is capable of.
Give this a go
1 - Don't use the FQDN in the domain property. If it's company.com, use COMPANY
2 - Capitalisation seems to matter as well. We've had success with ALL-CAP domain names
3 - Don't use a qualified user name (i.e. user.name@company.com just user.name
Try with and without encryption
Please feedback whether you are successful or not and what you did to get it to work.
I am a maintainer of that library and would like to know either way.
Ta.
simply create a SQL login and use it with SQL authentication
Hello again everyone. We just removed the domain and gladly it worked. I'm not really an IT guy so I apologize in advance and expect a lot of simple problems coming from me, though I'm working with our IT department for a project. They helped me fix this problem, sorry for all the trouble. Thank you for being always responsive.
