Hallo,
First of all...sorry for my bad english but i will try my best.
I‘ll try to commit on a MSSQL Database. But was i found is with Server Autentication. But i Need Windows Autentication. Is there an example of what shows me how to do it?
Hallo,
I am using Windows Authentication with my connection. In the settings in the MSSQL node, set the Domain to be either the hostname of your SQL server (if not joined to a domain) or the actual domain it is joined to. In the case below, JMT-XPCO is the hostname of the machine running SQL Server.
Hallo,
Thanks for your answer. I‘ll try it tomorow at work.
I tried. Unfortunately, the registration comes from the AD. Therefore, my login with username and password will be rejected.
