Although everthing worked fine for weeks, this morning, impossible to start my instance despite mutiple laptop reboots.
Logs says
[2022-12-20T15:55:03.709] [debug] [sshfs-mounts] No mounts to stop for instance "precise-hen"
[2022-12-20T15:55:03.709] [info] [precise-hen] sending shutdown signal to hyperkit process, waiting for it to shutdown...
[2022-12-20T15:55:06.160] [info] [precise-hen] hyperkit: [INFO] block recycler: triggering background flush: 597461 used; 29 junk; 424 erased; 1624 available; 0 copies; 0 roots; 0 Copying; 0 Copied; 0 Flushed; 0 Referenced; max_cluster = 599575
[2022-12-20T15:55:06.166] [info] [precise-hen] hyperkit: [INFO] block recycler: 0 cluster copies flushed; 0 cluster copies complete; 424 clusters erased
[2022-12-20T15:55:06.172] [info] [precise-hen] hyperkit: [INFO] block recycler: flush: 597461 used; 29 junk; 0 erased; 2048 available; 0 copies; 0 roots; 0 Copying; 0 Copied; 0 Flushed; 0 Referenced; max_cluster = 599575
[2022-12-20T15:55:11.180] [info] [precise-hen] hyperkit: [INFO] block recycler: triggering background flush: 597461 used; 29 junk; 0 erased; 2048 available; 0 copies; 0 roots; 0 Copying; 0 Copied; 0 Flushed; 0 Referenced; max_cluster = 599575
[2022-12-20T15:55:13.648] [info] [precise-hen] linkname /var/root/Library/Application Support/multipassd/vault/instances/precise-hen/pty
COM1 connected to /dev/ttys002
[2022-12-20T15:55:13.696] [info] [precise-hen] process state changed to NotRunning
[2022-12-20T15:55:13.696] [info] [precise-hen] process finished with exit code 0
[2022-12-20T15:55:13.700] [debug] [daemon] instance "precise-hen" does not need stopping
[2022-12-20T15:55:24.403] [debug] [precise-hen] process working dir ''
[2022-12-20T15:55:24.403] [debug] [precise-hen] Waiting for SSH to be up
[2022-12-20T15:55:24.403] [info] [precise-hen] process program '/Library/Application Support/com.canonical.multipass/bin/hyperkit'
[2022-12-20T15:55:24.403] [info] [precise-hen] process arguments '-c, 10, -m, 15360M, -u, -A, -H, -U, a1a2bf57-5f3c-3fa3-aefe-4b91d023d902, -s, 0:0,hostbridge, -s, 2:0,virtio-net, -s, 5,virtio-rnd, -s, 31,lpc, -l, com1,autopty=/var/root/Library/Application Support/multipassd/vault/instances/precise-hen/pty,log=/Library/Logs/Multipass/precise-hen-hyperkit.log, -s, 1:0,virtio-blk,file:///var/root/Library/Application Support/multipassd/vault/instances/precise-hen/ubuntu-22.04-server-cloudimg-amd64.img?sync=os&buffered=1,format=qcow,qcow-config=discard=true;compact_after_unmaps=262144;keep_erased=262144;runtime_asserts=false, -s, 1:1,ahci-cd,/var/root/Library/Application Support/multipassd/vault/instances/precise-hen/cloud-init-config.iso, -f, kexec,/var/root/Library/Application Support/multipassd/vault/instances/precise-hen/ubuntu-22.04-server-cloudimg-amd64-vmlinuz-generic,/var/root/Library/Application Support/multipassd/vault/instances/precise-hen/ubuntu-22.04-server-cloudimg-amd64-initrd-generic,earlyprintk=serial console=ttyS0 root=/dev/vda1 rw panic=1 no_timer_check'
[2022-12-20T15:55:24.403] [info] [precise-hen] process state changed to Starting
[2022-12-20T15:55:24.406] [info] [precise-hen] process state changed to Running
[2022-12-20T15:55:24.418] [error] [precise-hen] Using fd 5 for I/O notifications
[2022-12-20T15:55:24.427] [info] [precise-hen] mirage_block_open: block_config = file:///var/root/Library/Application Support/multipassd/vault/instances/precise-hen/ubuntu-22.04-server-cloudimg-amd64.img?sync=os&buffered=1 and qcow_config = discard=true;compact_after_unmaps=262144;keep_erased=262144;runtime_asserts=false and stats_config = None
[2022-12-20T15:55:25.191] [info] [precise-hen] hyperkit: [INFO] Resized file to 599576 clusters (76745728 sectors)
[2022-12-20T15:55:25.191] [info] [precise-hen] hyperkit: [INFO] block recycler starting with keep_erased = 2048
[2022-12-20T15:55:25.200] [info] [precise-hen] hyperkit: [INFO] image has 0 free sectors and 597461 used sectors
[2022-12-20T15:55:25.201] [info] [precise-hen] mirage_block_open: block_config = file:///var/root/Library/Application Support/multipassd/vault/instances/precise-hen/ubuntu-22.04-server-cloudimg-amd64.img?sync=os&buffered=1 and qcow_config = discard=true;compact_after_unmaps=262144;keep_erased=262144;runtime_asserts=false and stats_config = None returning 0
mirage_block_stat
[2022-12-20T15:55:25.202] [info] [precise-hen] /var/root/Library/Application Support/multipassd/vault/instances/precise-hen/cloud-init-config.iso: fcntl(F_PUNCHHOLE) Operation not permitted: block device will not support TRIM/DISCARD
[2022-12-20T15:55:25.334] [error] [precise-hen] vmx_set_ctlreg: cap_field: 2 bit: 22 unspecified don't care: bit is 0
[2022-12-20T15:55:25.334] [error] [precise-hen] vmx_set_ctlreg: cap_field: 4 bit: 12 unspecified don't care: bit is 0
[2022-12-20T15:55:25.334] [error] [precise-hen] vmx_set_ctlreg: cap_field: 4 bit: 20 unspecified don't care: bit is 0
[2022-12-20T15:55:25.334] [error] [precise-hen] vmx_set_ctlreg: cap_field: 3 bit: 13 unspecified don't care: bit is 0
[2022-12-20T15:55:26.419] [info] [precise-hen] rdmsr to register 0x3a on vcpu 0
