My dashboard doesn't work
Please add some UI nodes to your flow and redeploy.:frowning_face:
Anyone knows where is the problem please
Have you added any UI nodes & deployed?
Thanks a lot
I forgot that :sweat_smile::sweat_smile::sweat_smile:
Funny this should be posted, as I have test NR instance I use as a play area/sandbox and I get this message too, and it’s full of ui items (it used to work) ?
Any ideas ?
look at the startup log, any messages there?
Thanks, can you help me to find it, I have NR running in a Docker Container, but I can’t see it in the data directory, where is it exactly ?
No idea, never touched docker with Node-RED
I’m using Docker via My qnap NAS, so things are likely further complicated:-)
If you can let me know the exact file name and its extension I could try to do a host wide search..
Have you searched thru the forum? It seems to me this issue has come up a couple of times.
I’ve not done any deep digging yet, I just responded to this post as it was coincidental that I’d lost mine (something I’ve i stalked or changed has obviously caused it, as it has been working fine)
