Well, I really hoped I could get this myself, but it's not to be.
[{"id":"c592baad.37cc98","type":"inject","z":"c199b9b6.017a2","name":"start","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Not in the box!","x":680,"y":1080,"wires":[["a0afbcad.890128"]]},{"id":"a0afbcad.890128","type":"ui_template","z":"c199b9b6.017a2","group":"36e6edd6.dd93b2","name":"","order":2,"width":"3","height":"1","format":"<div ng-bind-html=\"msg.topic\"></div>\n<label class=\"swLabel\">Info:</label>\n\n<style>\n .swLabel {\n font-size: 20px;\n font-weight: 700;\n width: 50%;\n height: 28px;\n padding: 4px 10px;\n border: 1px solid #666;\n background: #cce6ff;\n color: #1c87c9;\n}\n</style>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":840,"y":1100,"wires":[[]]},{"id":"be443a22.28afb","type":"inject","z":"c199b9b6.017a2","name":"stop","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":680,"y":1130,"wires":[["a0afbcad.890128"]]},{"id":"36e6edd6.dd93b2","type":"ui_group","z":"","name":"Label Spacer","tab":"81831aab.f2f568","order":3,"disp":false,"width":6,"collapse":false},{"id":"81831aab.f2f568","type":"ui_tab","z":"","name":"GTO-500 Gate Opener","icon":"dashboard","disabled":false,"hidden":false}]
Should be 3 nodes, 2 injects to push and clear the msg.topic, and the template node with CSS. I really would like to replace the word "Info:" with msg.topic, not have it load above or below...
Russ
