Hi, I have a problem with the authentication of alexa-remote2-applestrudel, basically after configuring the profile and going to the page to activate the authentication everything works.
However, the problem occurs with each new deployment because the system requests each time to connect to the page, in practice it does not save the cookie or the socket that is to maintain the connection, which is rather stressful because each change requires the passage.
Incidentally... once activated if I don't do other deploys everything works.
As said I use nodered on iobroker installed on docker, any help is welcome.
Thank you
