"{"meterType":"ISK5\\2M550E-1012","version":"50","timestamp":"2021-12-19T10:01:24.000Z","equipmentId":"4530303433303036393938303836303137","textMessage":{"codes":null,"message":""},"electricity":{"received":{"tariff1":{"reading":5677.072,"unit":"kWh"},"tariff2":{"reading":5932.27,"unit":"kWh"},"actual":{"reading":0.269,"unit":"kW"}},"delivered":{"tariff1":{"reading":0,"unit":"kWh"},"tariff2":{"reading":0,"unit":"kWh"},"actual":{"reading":0,"unit":"kW"}},"tariffIndicator":1,"threshold":null,"fuseThreshold":null,"switchPosition":null,"numberOfPowerFailures":9,"numberOfLongPowerFailures":2,"longPowerFailureLog":{"count":0,"log":[]},"voltageSags":{"L1":8,"L2":null,"L3":null},"voltageSwell":{"L1":1,"L2":null,"L3":null},"instantaneous":{"current":{"L1":{"reading":1,"unit":"A"},"L2":{"reading":null,"unit":null},"L3":{"reading":null,"unit":null}},"voltage":{"L1":{"reading":228,"unit":"V"},"L2":{"reading":null,"unit":null},"L3":{"reading":null,"unit":null}},"power":{"positive":{"L1":{"reading":0..."
12/19/2021, 10:00:37 AMnode: json-node
msg.payload : string[1371]
The reading event returns the following data structure:
"meterType": "ISk5\2MT382-1000",
"version": "42",
"timestamp": "2010-12-09T10:30:20.000Z",
"equipmentId": "4B384547303034303436333935353037",
"textMessage": {
"codes": "3031203631203831",
"message": "0123456789:;<=>?0123456789:;<=>?0123456789:;<=>?0123456789:;<=>?0123456789:;<=>?"
"electricity": {
"received": {
"tariff1": {
"reading": 123456.789,
"unit": "kWh"
"tariff2": {
"unit": "kWh"
"actual": {
"reading": 1.193,
"unit": "kW"
"delivered": {
"tariff1": {
"unit": "kWh"
"tariff2": {
"unit": "kWh"
"actual": {
"reading": 0,
"unit": "kW"
"tariffIndicator": 2,
"threshold": {
"value": 16.1,
"unit": "kW"
"fuseThreshold": {
"value": 10,
"unit": "A"
"switchPosition": "1",
"numberOfPowerFailures": 4,
"numberOfLongPowerFailures": 2,
"longPowerFailureLog": {
"count": 2,
"log": [
"startOfFailure": "2010-12-08T14:20:15.000Z",
"endOfFailure": "2010-12-08T14:24:15.000Z",
"duration": 240,
"unit": "s"
"startOfFailure": "2010-12-08T14:05:03.000Z",
"endOfFailure": "2010-12-08T14:10:04.000Z",
"duration": 301,
"unit": "s"
"voltageSags": {
"L1": 2,
"L2": 1,
"L3": 0
"voltageSwell": {
"L1": 0,
"L2": 3,
"L3": 0
"instantaneous": {
"current": {
"L1": {
"reading": 1,
"unit": "A"
"L2": {
"reading": 2,
"unit": "A"
"L3": {
"reading": 3,
"unit": "A"
"voltage": {
"L1": {
"reading": 231,
"unit": "V"
"L2": {
"reading": 232,
"unit": "V"
"L3": {
"reading": 233,
"unit": "V"
"power": {
"positive": {
"L1": {
"reading": 1.111,
"unit": "kW"
"L2": {
"reading": 2.222,
"unit": "kW"
"L3": {
"reading": 3.333,
"unit": "kW"
"negative": {
"L1": {
"reading": 4.444,
"unit": "kW"
"L2": {
"reading": 5.555,
"unit": "kW"
"L3": {
"reading": 6.666,
"unit": "kW"
"gas": {
"deviceType": "003",
"equipmentId": "3232323241424344313233343536373839",
"timestamp": "2010-12-09T10:00:00.000Z",
"reading": 12785.123,
"unit": "m3",
"valvePosition": "1"
@ E1cid i got the path from a debug node,that why i am confused, in the dbug it give the value.
