So, I'm making daily backups of my Pi NR install and I need to grab a node from within the backup so I can re-import it back into the original.
What's going to be the easiest way to do this?
The backup I have is a complete archive of the .node-red folder on the Pi
So you want to import the flows.json from a backup and then copy one node from there into existing flows?
Can't you import that into another NR installation? You could also try the serverless NR to import the backup flows.json and export the node from there.
If that is indeed what you need to do.
serverless NR - Excellent solution - worked great
