Newbie - The workspace contains some nodes that are not properly configured
I receive the following message when I deploy a simple flow (a switch controlling the output of a Pi gpio):
" The workspace contains some nodes that are not properly configured:
  • [Flow 1] sw1 (ui_switch)
    Any help would be appreciated.
    Thank you!
Well have you set any options in the node?
Thank you for the reply.
If you are referring to node properties the answer is yes.
For the switch I have the following:
Group: [unassigned] Relay Control
Tooltip:
Icon: Default
If msg arrives on input, pass through to output: [box checked]
On Payload: [number] 1
Off Payload: [number] 0
Do you see any issues?
What version of Node-red and node.js do you have? You can find them in the node-red log.
node.js is version 10.15.3
node-red is version 0.20.5
it must be assigned to a group
How does one assign nodes to a group?
Click on the node to open it. Look at the option Group - it probably says Add new ui_group... Press the pencil icon next to it.
Look at the tab option and do the same
Thank You Zenofmud and Dceejay. The issue is now resolved.
