No data from the sensor in the MQTT node
I need your concentrated knowledge.
I ordered a new sensor (Dragino CPL03-LB)
I registered the sensor in the TTN and inserted the appropriate payload formatter. The sensor is sending, I see that in the TTN.
Username and API key created.
Created and configured an MQTT node. “Connected” will appear under the icon. It is not the first flow with Dragino sensors and MQTT nodes. Debug node in output shows no data or error message. What could that be?
Well,
You haven't really shared any information so help will be scarce.
1 - you need to check on this TTN system what you are receiving.
What is the message structure?
2 - What happens if you put a debug node on the MQTT IN node set to display complete message?
3 - What is the topic you put in the MQTT - IN node?
If you install MQTT Explorer on your PC and connect to the MQTT broker then it will show you all the data being published so you can find out what topic you need to subscribe to.
That was very helpful. Data in MQTT Explorer right there. I had entered the MQTT node in the topic (v3/contact..instead of v3/kontact.... But I was still connected. Thank you very much!
Connected means that it has connected to the browser. The node has no way of knowing whether anything will ever be published on the topic that you specify.
