This maintenance release improves some of the ways you can edit and work with groups in the editor:
Fixes an issue with copy/pasting of groups containing nested groups
When editing a group's contents (shown when the group's border is dashed):
the lasso select (drag to select) option now works on the contents of the group
Ctrl-A (select-all) applies just to the contents of the active group
Ctrl-clicking on a nested group now behaves more intuitively
It also improves the performance of dragging groups around the editor. There's more work to be done in this area, but hopefully each release brings some incremental improvements.
Started : gio 6 ago 2020, 10.48.52, CEST
Running for user pi at /home/pi
Found global nodes: :
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Lettura elenco dei pacchetti...
Generazione albero delle dipendenze...
Lettura informazioni sullo stato...
Il pacchetto "nodered" non è installato e quindi non è stato rimosso
I seguenti pacchetti sono stati installati automaticamente e non sono più richiesti:
alsa-base gstreamer0.10-alsa gstreamer0.10-plugins-base
libgstreamer-plugins-base0.10-0 libgstreamer0.10-0 libllvm8 libmicrodns0
libva-wayland2 libxfce4util-bin libxfce4util-common libxfce4util7
libxfconf-0-2 pimixer point-rpi rpi-eeprom-images xfconf
Usare "sudo apt autoremove" per rimuoverli.
0 aggiornati, 0 installati, 0 da rimuovere e 0 non aggiornati.
Already have nodejs v12.18.3
Now install nodejs
Versions: node:v12.18.3 npm:6.14.6
Now install Node-RED
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated bcrypt@3.0.8: versions < v5.0.0 do not handle NUL in passwords properly
npm ERR! code E404
npm ERR! 404 Not Found - GET https://registry.npmjs.org/@node-red/editor-client/-/editor-client-1.1.3.tgz
npm ERR! 404
npm ERR! 404 '@node-red/editor-client@1.1.3' is not in the npm registry.
npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
npm ERR! 404 It was specified as a dependency of 'node-red'
npm ERR! 404
npm ERR! 404 Note that you can also install from a
npm ERR! 404 tarball, folder, http url, or git url.
npm ERR! /root/.npm/_logs/2020-08-06T08_50_28_132Z-debug.log
Now create basic package.json for the user and move any global nodes
Installing extra nodes: node-red-node-pi-gpio@latest node-red-node-random@latest node-red-node-ping@latest node-red-contrib-play-audio@latest node-red-node-smooth@latest node-red-node-serialport@latest :
npm WARN node-red-contrib-ui-led@0.3.1 requires a peer of node-red-dashboard@2.14.x but none is installed. You must install peer dependencies yourself.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
node-red-node-smooth@0.1.2
node-red-node-random@0.2.0
node-red-node-pi-gpio@1.1.1
node-red-node-serialport@0.10.3
node-red-contrib-play-audio@2.5.0
node-red-node-ping@0.2.1
updated 7 packages in 49.541s
Now add the shortcut and start/stop/log scripts to the menu
Now add systemd script and configure it for pi
Now add launcher to top bar, add cpu temp example, make sure ping works
L'utente «pi» fa già parte del gruppo «gpio».
Memory : 3,8G
Finished : gio 6 ago 2020, 10.48.52, CEST
I don't know if my problem is related to this release but just after upgrading to 1.1.3 (I think from 1.1.0) the TreeList Widget do not show tick boxes any more. I think I haven't changed anything in my code.
The objects for the entries have the selected property (initially false):
