🎉 Node-RED 3.0.0-beta.3 released
WTH?
Can you check the browser console please Paul, see if there are any errors?
Then after that, restart node-red & refresh browser cache?
Also, list any chrome add-ins you might have running?
Lastly, if still no good, could you share your contrib nodes (and plugins) please?
Ta.
Browser console reports;
[Violation] 'mousedown' handler took 265ms
[Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
Restart node-RED - still the same
Tried 'incognito' browser window, and works OK :grin:
So must have been a browser caching issue, which didn't clear when using F5, but shift-F5 did clear the problem.
(The click-right menu issue mentioned above still persists)
There's a visual glitch at the right-hand sidebar content selector.
Chrome (Version 102.0.5005.115) & FireFox (101.0.1 ) & Safari (Version 15.5) on MacOs
I was about to raise an issue about this. I noticed the same in the visual editor.
Screen Shot 2022-06-16 at 3.15.05 PM
Please do get it raised as an issue.
Ctrl + click to add a node issue happens to me also
doesn't show when you are at the top of the flow but
it happens when we scroll further down the flow and ctlr-click
(tested firefox - chrome)
Ooh, yes. I scrolled down the page then did ctrl-click and got this:
Latest version of Edge on Windows 10. NR has been restarted and the cache cleared. No errors in the browser dev console.
I should say that I have a slightly adjusted colour scheme but nothing drastic, just tones down some of the bright white.
If I click to add an inject node, the display returns to the expected one.
Please could one of you raise an issue for this (ctrl-click disappearing nodes when scrolled)
Not that it helps, but no obvious issues with the right click context menu on my chromebook (connecting to a clean install of the node-red beta on ubuntu to ensure no 'garbage' in the config).
And as a bonus, I can now easily make junctions, which I couldn't before in beta2 with the keyboard/mouse shortcut route (on a chromebook).
Another topic concerning the (new) right-click menu: Shouldn't the menu disappear when we change the selected "context"?
  • Initial right click on blank canvas -> menu appears.
  • Left click on debug node -> changing context ... yet the menu is still shown.
tester
Now fixed in git:
  • menu icon padding
  • quick-add dialog positioning when scrolled
  • cannot type a space in the JSON visual editor
Still need to investigate the cross platform issues with the right click menu.
If and when you do add this, can it be made export / importable? (Future note).
3.0.0-beta.3 Docker containers are built.
Please read the following announcement about Python in these builds
Is there a command I can run to revert to beta2?
try
sudo npm install -g --unsafe-perm node-red@3.0.0-beta.2
ps. but why revert .. better keep the latest beta 3 and report any issue you notice
I am using Safari and it is working.
Perhaps related: I cannot type an @ via option + l (Small letter 'L') on Mac ... in any of the input fields (might it be code of a function node or just to define a label). Confirmed to be OK on 2.2.2.
No problem on my mac, with chip apple M1
Some additional information: I guess this effect is related to the (keyboard) shortcut system of node-red. v3.0 introduces new shortcuts, in that special case "option + l" - which wasn't used in v2.2.2. Those shortcuts are always present ... and block the standard keyboard operation when typing into an input field.
An example: Open a function node, put the focus into the script editor field ... and push "option + w". This should create the letter "∑" - it yet hides the current flow! I can reproduce that behaviour in v2.2.2 as well as v3.0-beta.
Preliminary summary: This is not a distinct v3.0 issue - but rather a general node-red (design?) topic. Despite I'm uncertain if this behavior is intended or documented, it feels wrong for me. Let me propose to raise an issue "Mac: Keyboard shortcuts always active; prevent standard keyboard operation in input fields." Any better denomination welcome.
No, it erases the flow I'm on. I tried it on my flows, with the result that they are all deleted.
If a copy is not saved, they are gone forever.
Be careful with (option + w) on Mac.
Correction, I found out they have been hidden.
