Node Red application keeps quitting
Hello Everyone,
I have installed Node Red into our Oracle Linux (Red Hat based) instance and after a while, the browser just updates and comes up "Safari cannot connect to server"
I have to go back into the instance and type the command node-red-start.
Is there a setting where Node Red can continue running without having to type the command?
Thank you in advance,
Michael
On Linux, you would typically set node-red as a service (search net for setting up a service on Oracle Linux (Red Hat)
As for why it is stopping, what does the log say?
I can't find the log.
I am assuming it would be a timeout after inactivity...
You know what they say about assume :wink:
No, node-red does NOT simply stop after a period of inactivity. It stops when told to OR your code crashes it.
Check the syslog of your server running node-red.
my apologies for the assumption.
I am getting back on track to get this 4 year long project to completion, and I am nervous at the same time as looking forward to getting this finalised.
I have emailed our Oracle Cloud contact to advise of this. Hopefully they will provide the answer.
There is no code in Node Red right now..
Does the command node-red-log work for you? If it shows the log then leave it open and see what happens.
Hello Colin,
Thank you for this,
I will keep it active and hopefully I will be able to catch it when it occurs.
Wait, are you opening a terminal & starting node-red via the command node-red?
Then are you closing that terminal?
If so, you are ending the session when you quit the terminal & need to run node-red as a service.
That makes sense.
When I time out of Oracle Cloud or when I log out of Oracle Cloud, that is when it occurs.
You must setup node-red to run as a service. How you do that on oracle cloud I don't know, but presumably their docs will help you out.
